- Jun 22, 2015
New firmware released, only fixes a playback transition issue when listening thru BT.
Not sure why nobody answered it but yes. You need to have the updated 2.0+ (IIRC) FW then you will have the BT receiver option, then simply connect your phone to the ZX300 and stream. I use my Note 9 streaming LDAC to the ZX300Is there any way I can stream Tidal from my Samsung phone to the ZX300..?
To anyone who has updated, has the sou d changed at all? I know a few from the 1A/1Z thread had mentioned a change in sound so I was wondering if it would be the same story with the ZX300
Lmao yeah it uses BT 5.0 and it does have LDAC support but not AptX HD as Samsung stupidly wanted to use Samsung HD which they now removed as a codec option lol.how does that work? samsung note only uses bluetooth 5.0, not compatible with ldac or aptx hd, are you sure your note 9 is using regular bluetooth 4.2 at 320kbps to your nw-zx300?
I just upgraded to 2.02.. Yeap, it does sound bit brighter & more detailed than 2.01.. Like Astell&Kern SR15 or am I just imagining things? But anyway, no regrets - SQ now is at least the same or a tad better than 2.01..I feel this update make the ZX300 sound a bit, just a bit brighter & more detail than 2.01, or I just listening in a quiet room
My impressions are based on direct playback from microSD source, not Bluetooth..Are the perceived changes in sound referring to the Bluetooth output only?
