audioaudioaudio
Confirmed on one Japan bought model and two UK bought models so far I think, so seems to be generic. It was just the original poster noticed the option while playing with their Japan model before changing the region to get English.
My play count is intact, just seemed to reset any menu options you have changed and clears any BT devices you paired, playlists still there but can't remember if I'd used the bookmark feature so not sure if that remains.
good to know thank you
Just to confirm this, mine is UK. Although I don't use playlists often it's nice to have the ability to create them and the naming of them is much handier than trying to remember which bookmark list I might have added things to. Still find it a bit bizarre it's only available on the Japan region but maybe it'll get rolled out to the others in future firmware.
Some early thoughts:
- Absolutely love the sound and the DAC ability, it has proved to be a great pairing with my old Z1 Compact running Tidal. Certainly a step above having a DAP running an older Android than my 4 year old phone, hammering the battery with wifi and processes etc. The Z1 is just used for Tidal + Subsonic, has 128gb mainly used for mp3 mixes and radio shows too and is practically the same size as the ZX300 which is good for portability.
- The size is perfect for me and the build is really impressive, it feels like a device that costs £500 which is nice!
- The battery life has impressed me so far, I normally have Bluetooth + NFC off, volumes between 50 - 80 with High Gain out of the 3.5mm. One full charge on Monday night and still showing full with a good few hours put in. It will be interesting when I begin to copy over a lot of my CDs in FLAC. I plan to get a 400gb card but will use a 256gb in the mean time, just slightly wary how slow the database scans will be with a very full 400gb - will report back when I get to that point.
- It's great to have the sound enhancement options, I've had a play and the EQ gives a nice range of flexibility but I've been pleasantly surprised that I really haven't needed, the sound so far has been great via direct.
I ordered the basic £4 silicone case which I think comes with the plugs which will be handy, later in the year I will trial the N3AP and get a 4.4mm cable and the official case from Accessory Jack I think. I will also buy a WMC-NWH10 cable at some point as that will come in useful I think.
Two things I'd like:
1) Sony to sort the jpg cover issues, I will currently have to run through a fair few of my collection I think to re-save those in Photoshop which is more than a bit annoying. I'm still seeing if I can find a way to automate it before embarking on that one.
2) Sony to put me on their User Testing list to trial a 750gb / 1tb micro sd card that they've kept secret until now
