Magnepan Man
- May 4, 2013
Okay. Just found out that direct mode is Not where you want to be, even if you don't engage any of the eq or sampling sound settings. By turning off the direct mode, and still leaving he other settings disengaged as well, you get the best bass response and sound stage. When you put the direct mode on, something negative happens and the bass is lessened, and the stage is also not as decipherable. Instruments loose weight This phenomena seems counterintuitive to what a direct button should do. but that’s what I hear. It’s quite noticeable. Anyone care to check it out and report back? The direct mode seems to do some weird graying out effect to the music. Like there is a phase issue on the bass. You can hear it very much with synthesizers. Try it and I bet you’ll hear it to.
