raybies
- Nov 27, 2016
It's confusing, dear I say on purpose.I'm obviously misunderstanding what your after. You must mean like a line-out, not as a DAC.
Sony sell the WMC-NWH10 which is a WM-Port to USB Audio Out (with unknown standards) the cable pinout is different to USB Data as it has a pin for USB standard negotiation eg (UAC2).
http://helpguide.sony.net/mig/Z003869611/EN/contents/TP0000627708.html
This is different than USB Data, I just need to test an application which uses a XMOS proc (https://www.xmos.com/download/private/Why-do-you-need-USB-Audio-Class-2?(1.0).pdf)
The problem is they charge some A$90 for a stupid $2 cable, so I'm looking for a clone. I fear the FIIO L27 is just a short data cable.
Edit: according to Sony website, it can be done. Looks like they are up to firmware 1.10
Nope, you have to create playlist(s) first then copy them over, and then you can add to it. The album art stuff will piss you off too.
