ailean
- Apr 10, 2017
Seems right up Sonys mindset though, everyone else uses 3.5mm or 6.3mm oh and some non major people are starting to use 2.5mm so I know lets make something new 4.4mm.Sony didn't make nor design the 4.4mm standard.
It's just the simple fact that the 4.4mm part is a niche audiophile product which currently has no other application so the manufacturers aren't jumping head over heals to mass produce them, unlike 2.5mm or 3.5mm or even XLR parts which are not limited to audiophile usage.
I do suspect it'll never be a major standard, balanced is a niche within a niche, so chances of things like the low level 6.3mm adapters where the 3.5mm plug actually goes inside the 6.3mm plug space or the screw locking ones are very low. I don't think a lot of the other DAP makers will switch to 4.4mm from 2.5mm either as it's a lot bigger socket to make room for and few high end DAPs have any room to spare inside.
Shame as I kind of prefer the 4.4mm over 2.5mm, the smaller plugs just don't hold well in the sockets and I've found them getting pulled out a lot easier then standard 3.5mm ones. I do kind of wish they'd reused the 3.5mm remote plug idea for the extra pins but guess that would have confused people and might have lead to things going POP if plugged in the wrong thing.
