NaiveSound
- Nov 8, 2015
How is this player compared to wm1a in sound quality alone?
But it is mysterious to them - everything you said above was already mentioned in the e-earphone video interview regarding the chassis ground design/PCB board ground contact with chassis and anodizing etc, but again it's the only variable the Sony engineers can think of between the silver and black version, hence Sato-san came to the conclusion that perhaps the thickness difference of the alumite between the silver and black version is the cause - as he said so in the video. Notice he never stated this as a statement of fact, but with the lack of other variable factors to account for this is the one difference he came to point out. In previous development interviews for the WM1 series they also highlighted how they found that even with the same material of different purity can cause an audible difference (their claim - not mine, and again I'll point out this is just similar to the school of thought regarding things such as OFC in cables), if they have that kind of thinking then it's pretty natural for them to come to the conclusion that the more anodized black version with paint and stuff which has undergone more chemical processing is cause of the difference.
Personally speaking I think a placebo effect with the colour is as much of a plausible explanation to account for the difference - until they can put together an ABX test to show otherwise.
Just more BS..... Still no sign of logic anywhere.
Putting aside actual audible difference, there's still several layers of hypothesis going on here and you'll have to break it down one by one:
1) first, the idea of a tying PCB ground to chassis ground is a supported electronic design practice - so no dispute here
2) now supposedly the material used for this chassis ground is going to have an effect - this at least checks out in the equations because the chassis ground/reference voltage point ideally should be zero with infinite conductivity, yet no material is like this so some level of difference will occur in the real world
3) now the purity of the material as a whole - hmm maybe? As an extension of 2 it's at least an interesting suggestion < - where they are at
The logic is actually there - is it BS? I dunno, I think there's at least enough grounds for a proper test to demonstrate it.
Then what on Earth is the copper grounding plate they bring up in all their marketing for?- this is either functioning as a ground for the PCB or as a seperate signal ground for the audio circuitry, in either case the chassis would carry no analog signal current. The only electrical function I can imagine the chassis serves is EMI protection.
With all this talk about the chassis, there is some mention of it on Sony's Japanese website (Google translated so the phrasing is a bit awkward, but I think the idea comes across):
SE846's are great but am looking for Headphones (non-in-ear)... also want to avoid cables and adaptors (looking for one-stop solution). Maybe I’m asking for too much, but the 4.4 mm “standard” has been around since 2014?Well DSD via SE not that bad considering not Native. Chord Mojo & Hugo2 much better, but hopefully will do once the Sony balanced 4.4mm cable arrives for my SE846's.
Everything else sounds fabulous, even in DAC mode with Tidal HiFi especially good via UAPP app.
Tidal on PC with ZX300 doesn't seem to pass MQA and I also downloaded a demo MQA file to the ZX300 itself and doesn't seem to see the track. Is MQA enabled yet?
My setup now with Z5 compact linked together. Really neat and not to heavy.
I really like how when it comes to sound/head-fi, every little thing becomes a variable. Like when we talk about gaming setup, we don't discuss about stuffs like how sli hard bridge performs better than soft one, and we do not talk about having a case with better grounding would give you some extra FPS.
