- Oct 14, 2013
So I can used balanced TRRS cables on it? And it will sound better?
If it has the correct terminals , then yes!
And it will sound better??????
I agree with Whitigir. I made one trip with the dock and it was a pain. Go with the dongle cables.
Another test for the cable - wow...really loving how KSE's sound now. Never really liked the KSE and its Amp in line in mode, so its been collecting dust for awhile hehe.
Don't agree with the 'mind-boggling' part ($4000+ for a DAP, anyone?), but I can see where you're coming from, the enhancements and unique audio circuitry are a bit lost with use as a storage. But I have to agree with Whitigir, the digital out from the ZX2 is no slouch, I prefer it over analog in all situations that I've tried (with the Shure KSE1500, the Chord Hugo, etc). I'd go so far as to say it's noticeably better than the digital output from some 'mind-boggling' DAPs which shall remain nameless
For me, not sure what exactly Sony did, but it shows. Now to get off my butt and actually get one of those cables for myself. I still don't get how Sony can't just release a digital out -> micro USB cable themselves, instead of needing that clunky adapter.
Edited for clarity/typos.
That's exactly what I mean. When you use the ZX2 as a pure storage device, and I think that's what is happening here, you bypass its digital amplifier and also its DAC, yet that's where all the (expensive) magic is coming from. I can understand why you prefer the digital signal. I use a digital cable, too, to connect my ZX2 to my HP-V1 tube amplifier. However, I still get enjoy the audio bliss coming from both the audio circuitry and sound enhancements.
Aren't there cheaper ways than buying a ZX2? There must be cheaper devices offering digital outputs with good quality.
Anyone willing to be the first to have a go with one of these? The launch price is a lot less than I was expecting for the UK.
Have you seen this post ?
http://www.head-fi.org/t/742609/sony-nw-zx2-hi-end-dap/11490#post_12558710
Sony is unique in offering more power and quality to Digital signals for audio than anything else out there. Either the dongle cables or the cradle will hugely increase the sound quality coming off your Zx2 in digital mode. Do not use cheap China made cables.
Have you questioned yourself as why Zx2 drain more battery in digital mode ?
Alright, I just have to stop you right there. If a cable meets the minimum spec for USB 2, then it is massive overkill for digital audio. 24/96 audio in stereo uses 4608 Kbps. USB can handle 280Mbps. That's 280,000Kbps, or a little less than 61x the required bandwidth. So if it meets spec, it will be able to carry the signal just fine. You can use more expensive components, but it's absolutely impossible for them to matter. Now, it might be that the connections on the cheaper cable are in fact no good, but they'll either work or they won't. So long as it meets spec, you'll be fine.
With regards to using the ZX2 as a transport, if the DSP and EQ are good, and it applies them before outputting the signal, then there is definitely reason to use it. If it applies no DSP, and it just does a bit-perfect output, then it's the same as any other device that's bit-perfect. The DSP on the ZX1 is pretty good, but I've never tested it through the digital out, I probably should. The crossfeed options are quite noticeable on the ZX1, and (some of the options) are pretty darn good. Not up to the level of anything that Joe Boggs has provided out of the goodness of his heart, but definitely good. If those are applied to the digital out, then I'd say it might be worthwhile, assuming that you can afford the ZX2.
