JeremyLaurenson
- Jan 3, 2011
Anyone have a better way to re-disable the Audio Settings app on restart? Seems like you have to enable it, reboot, then disable again
Yeah, I've run into this with a ZX1 (same UI, right?). I understand it's an Android restriction, not the Sony digital out hardware.
Btw, it doesn't seem like Sony is going to upgrade zx2 or so, at ces2016 and they only announced rainbow color on A26 which is A17 successor ?
Hmm, seems like ZX2 will have another good year of listening then
Sigh...after a couple hours of A/B, plugging, un plugging, critical listening sessions...etc. I don't even think ZX2 is a good match as a transport into the Mojo, and is an obvious waste of money. My Note 4 has better transparency and soundstage on 24/96 files feeding Mojo than Zx2 feeding the same signals. I think it is due to the ancient android on Zx2 somehow limiting data out badly ? Onkyo HF app can not even feed 24/96 into Mojo from the zx2, and only stock app can.....yeah, it doesn't even sound as decent as note 4 with android 5.1.....
Beside, note 4 with Onkyo HF player and up converting to DSD feeding Mojo is also very fun. Though it is always best to stick to the original source.
***unless zx2 has a firmware upgrade***
It doesn't matter what transport you're using if it's digital. It's all 1s and 0s man. You could use a crappy cheap o android, if it's otg digital going into the mojo, it will be exactly the same coming out of the mojo as the zx2, or anything else. This is assuming you're listening to the same source file .
Can't believe I'm saying this buy the MoJo was meant for mobile phones, that is according to what I read online. Nevertheless that is definitely an unexpected outcome. Because the ZX-2 would only be providing the music to the MoJo.
I do listen to the same file, only on different micro SD. What I am saying here is that ZX2 android OS restrict the high-res data output. I can not use Onkyo player to feed mojo my 24/96. I can only my note 4 to Mojo on the same file.
Now zx2 stock player app will output high-res 24/96 into Mojo....but it doesn't sound as transparent or with that good soundstage as Note 4 feeding Mojo the same 24/96 file.
I do not know what cause it ? More likely the algorithm, the software ? The OS ? We all know digital is 1 and 0, hence it needs software and algorithm to puzzle it up ? And the way it get puzzled together would create the final picture ?
From your stand point, why can't the same Onkyo app output 24/96 into Mojo from Zx2 ? But the same file and app can be feeding into Mojo from Note 4 ? Hmmm ?
Ok, I see what you're saying. Have you tried Universal Audio Player Pro? I think you can get a trial demo.
Sorry, it's USB Audio Player Pro. You can get a time limited demo for free to test. It was made especially to bypass android audio and output pure digital. Go into the description for UAPP, and there's a link there for the apk to the trial. The good thing about UAPP is that it works with a lot of external DAC/amp combos.I don't see it on Market place ? I decided to stick with Onkyo HF Player app is because it does so well on Zx2 as a stand alone DAP, and I was unable to use the stock note 4 app to play music over OTG cable into Mojo....instead of paying another 7.45 something into another app as USB player pro ? I rather pay for Onkyo HF player as I am already familiar with it
Hmm, no trial available, it cost 7.99 but I refunded it back.....here is why
