proedros
very helpful thread , thank you for your hard work
cheers
Regarding separation, I perceive the output to be very coherent.
maybe but my iems are K3003 which are not so shabby so maybe it was a bad recording that sounded muffled ? hm.....
i am gonna buy some new iems though , you know how this place works voodoo on your mind
is it my idea or is the separation kinda lacking ?
soundstage, yes immense
bass, robust
but something bugs me about the separation ....i sometimes feel like my dx90 has better separation
anyone who shares the same 'sand in the shoe' feeling ?
hello
finnaly i decided to boost my EU ZX2, i want to use them with my Z7 and any other headphone other than iems. it will be a cheaper solution than 846
any suggestions for cabling between B1-zx2?
many tnx
off topic ? matchin amp with zx2? anyway i might wait for a while to see the new amp, IeMs will be fine even with EU ZX2 ( my share 535 are just fine ) so headphones only is ok
Thanks. That's very helpful. I confess I haven't even started thinking about different cable options. Do they really make much difference?
The meaning of "much difference" is defined by your taste and expectation. I believe that using a balanced setup provides a noticeable difference for me. Whether you think it is worth the cost of using that feature can only be determined by you trying it.
Truthful enough....my opinion, I can not listen to ZX2 without TRRS anymore
Yeah I have come to the same conclusion, I think the TRRS hasn't been made so apparent by Sony is because most of their own headphones can not work with it of the shelf.
And it would seem it's being left off other walkman models for the sake of useless N/C.
But I can't use the zx2 without it now, it is just the best soundstage I have experienced with it.
Pay attention to the low end with the DSEE HX on. That is why I stopped using it rather quickly.
