animalsrush
- Aug 15, 2005
Sorry about that . Yeah, it shows up as yours does...when playing music and hitting the volume. I went to look for it in settings when I wasn't playing music as it doesn't go to landscape (even with the auto rotate box checked) when not playing music at the home screen. Does however rotate to landscape when playing music...
So far I'm enjoying the player, but I need to get some new iem's, it seems, to get more of what's available out of it. I've been using UE10's, which were their top offering January 2007, and while they are decent with a desktop/transportable setup, they just can't be properly driven by the ZX2. Comparing between a simple old micro stack from Headroom and the ZX2, the UE10's have great bass, deep and controlled, and overall excellent authority, and solidity. With the ZX2, they are merely passable, with some material sounding quite good, but for the most part just fairly good. Certainly a step up from the DX90 on it's own, but I know it can be better; listening with my Sennheiser ie800's, I'm able to hear OUTSTANDING resolution on a lot of material, not all of it hirez, but flac at least. I think this combination is quite good, and perhaps good enough for most purposes, but I'm spoiled by the custom molds from my UE's, so I think I'm on the path of picking up a newer pair, as certainly there have been improvements in the last 9 years!
Still, with the ie800's, it really is glaring how much more fuss it is to get a proper seal, and so they stay that way, especially when active. I've actually super glued the tips on these as the way iem's are designed, the tips can (and have on more than several occasions in the now distant past) come off inside your ear canal! I've even had the unpleasant task of changing one of the tips, having to remove a slightly larger tip that had already been glued. I would have replaced both with the slightly smaller size (now that they are glued, I can more freely insert a smaller tip to more easily get a good seal) but the other one is lost somewhere up in the mountains, as one of the aforementioned incidents where a tip came off in ear occurred while hiking over heather, and could not be found...but I digress.
Because of these concerns and more, I'm ready to get a new pair of IEM's, and I'd love to know what the top three consensus ones may be. I see people mention JHAudio monitors for instance, Roxannes. But maybe not Angie's. $2,600.00 is a bit much, given that they are not the 'end all be all' of IEM's, present and future. Steven Rochlan gave some MIGHTY praise for his Noble 10's, notably with the ZX2. The main selling point for me with the ZX2, is that I wasn't quite there with the DX90 (at least unamped, with my meager choices for headphones) and the BATTERY LIFE. I've invested absurd amounts of money (especially relative to my income) into my home rig, so for my portable player, I truly want it to be able to be portable (even use it jogging!) to play music for 18 or more hours and longer if I'm on multi day trips in the backcountry (hiking, camping...). I think the Headroom Microstack sounds great. It sounds better (say with the DX90 feeding the dac/amp stack with digital connection) with the ie800's, than the ie800's and the ZX2. It just goes to show how important proper amping is, I guess. But the Microstack is simply transportable. Certainly it's nothing that I would ever carry with me while hiking or something, and the battery life for the re-chargable Maha 9 volt batteries is quite paltry, less than 5 hours I'd say. So I LOVE the idea of being able to take really great sound on the go, and I've mostly held off purchasing newer players. I've always wanted one of the top Hifiman players, but again, battery life and size just don't work for my purposes. I like the ZX2, and it's quite good with the ie800's. Actually it's plenty good for me to justify the purchase, as the resolution is so clear, and sweet, and it can play for days(!) on end, or at least well into the 30's if a lot of hi-rez is on tap, but still; to get sound this good, and it is stunning with the right material, in a one-unit package is sufficient for me and fills my needs. It's just unfortunate to hear the same iem's handled with undeniably more authority, showing me that they are not amped to their potential. But this is the best unit for my needs likely, and I'd like to take it a little further, with the built in benefit of new CIEMS being that I'll have them hopefully for the next ten years.
So any thoughts on the BEST match that folks have found with the ZX2 in terms of CIEM's would be most appreciated. I'm already planning my trip to the audiologist to get my molds made. Though preferably under $2000.
Thanks.
Nathan
I use Westone ES5 with my Sony zx2.. Personally I feel they have great synergy. Details are crisp, bass controlled and deep but not pounding. I find the combo least fatiguing. ES5 have near neutral signature and I use stock player with clear bass +2 that's it.. So they are worth trying..
Pc
