Zaroff
- Mar 10, 2004
I suggest we can go back on topic of this very fine player
![wink.gif](http://files.head-fi.org/images/smilies/wink.gif)
Agreed...I suggest we can back on topic of this very fine player![]()
I have just got the EU ZX2 and I have been comparing it with the iPod Classic+ CLAS DB + ALO Rx MKIII B combo and I can immediately tell the ZX2 sounds better. ZX2 is smoother with great soundstage while the CLAS/Rx combo sounds a bit unrefined and bit edgy. I didn't have the right cable to use with my Miracles but with HD650 (ZX2 is near its volume limit) the ZX2 sounds phenomenal. Just wish it had more juice to drive bigger headphones. I am getting the Hugo this week as well so I will be able to do the comparison.
I try install file explorer (ES File Explorer) from play store. With file explorer I can copy or delete files on external sdcard
So the restriction only applied if we try to write files from outside of ZX2 (via wifi) to external sdcard
Anyone here that use Spotify or Tidal (or any streaming services that allow you to download songs for offline use), please try if you can download songs to ZX2 external sdcard. Thanks
I just installed ES File manager and was not able to delete files from external sd card. Are you sure you were nit deleting from sdcard0? Sdcard0 is internal card and sdcars1 is the external.
But, you can delete songs from external sd card using Sony music player, however.
Whether I receive condemnation or not, I do not mind, however have to say that the combination of 1p2 and ClearAudio+ is awesome... I really, no, REALLY like this![]()
