gerelmx1986
In balanced with the battery care set to on, I get like 20 hours
I actually really wanted to buy the wm1a so i can have one dap instead of iphone+neutron+mojo setup. But after listen to wm1a vs my current very inconvenient setup, i somehow prefer the mojo. I was comparing balanced cables with z7 z1r and se846 and play off my own SD with wav and dsd files for almost 2 hours. I mostly listen to volcas. May be i should give it more time with different kind of music? Not sure if i want to spend 1k+ for wm1a anymore, it just doesnt jistify the price vs mojo, of cause minus the iphone which i already have.
I actually really wanted to buy the wm1a so i can have one dap instead of iphone+neutron+mojo setup. But after listen to wm1a vs my current very inconvenient setup, i somehow prefer the mojo. I was comparing balanced cables with the store z1r my mod z7 and se846 and play off my own SD with wav and dsd files for almost 2 hours. I mostly listen to volcas. May be i should give it more time with different kind of music? Not sure if i want to spend 1k+ for wm1a anymore, it just doesnt jistify the price vs mojo, of cause minus the iphone which i already have. And i did try the new onkyo phone-dap as well as AR dap and few others, non of them are as good as wm1a, the power off balanced just so strong all others sounds thin and light. Also a lot of my misic uses cue files which sony doesnt support.
We all have our own preferences, nothing wrong with that. If you find after spending time with the Walkman it doesn't grab your attention, that's fine.I actually really wanted to buy the wm1a so i can have one dap instead of iphone+neutron+mojo setup. But after listen to wm1a vs my current very inconvenient setup, i somehow prefer the mojo. I was comparing balanced cables with the store z1r my mod z7 and se846 and play off my own SD with wav and dsd files for almost 2 hours. I mostly listen to volcas. May be i should give it more time with different kind of music? Not sure if i want to spend 1k+ for wm1a anymore, it just doesnt jistify the price vs mojo, of cause minus the iphone which i already have. And i did try the new onkyo phone-dap as well as AR dap and few others, non of them are as good as wm1a, the power off balanced just so strong all others sounds thin and light. Also a lot of my misic uses cue files which sony doesnt support.
Take a look at post #855.Apologies, I tried to search, in vain.
Is there a guide somewhere in how to modify the Japanese 1z to English?
