Tawek
- Nov 18, 2015
scsitool-nwz-v6.exe D: dest_tool get set E2 off ? Nothing happen
Did you read the instructions? Did you try the get to get current settings? Did you reboot after?scsitool-nwz-v6.exe D: dest_tool get set E2 off ? Nothing happen
Taking about the instructions, what does rest the setting means?
mine as well, WM1AThe Sony WM1Z has Panasonic capacitors as well, it says in the guide to high quality sound to burn in for 200hrs to reach high quality sound. I bought mine this year in April 2017.
Haha,Effect Audio Ares II 4.4mm Balanced just came in.
