SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Apr 1, 2017 at 9:04 PM Post #10,921 of 45,723
Regarding the remote RMT-NWS20.
Any1 have the manual, mine is in Japanese.
Somehow mine failed to function after few days, thought its the batt but then it came alive with flashing of blue lights....
Apr 1, 2017 at 9:25 PM Post #10,922 of 45,723
Thats because it's only officially available in Japan.
Apr 1, 2017 at 10:10 PM Post #10,923 of 45,723
J've identified the rebooting problems with my WM1A, faulty transfers to my SD card LOL, removed it withouth the safely eject hardware hehe
Apr 2, 2017 at 1:00 AM Post #10,924 of 45,723
https://twitter.com/flubber777/status/848361696317939713
[size=medium]For those waiting for 4.4mm female to 3.5mm SE or 2.5mm balance (or looking to hack to other connectors like XLR). Soon. [/size]
Apr 2, 2017 at 1:09 AM Post #10,925 of 45,723
Did you check if the Hold is switched off before using?
You can reset the remote pairing by Holding "play/pause" + "Vol -" for 10secs.
With "Hold" switched off that is.
You will see flashing alternating Red and Blue lights which is pairing.
Very useful remote. I asked my friend get one for me from Japan.
Sold out in China and low stock in Japan.
Apr 2, 2017 at 3:02 AM Post #10,928 of 45,723
Yes, I did releaseed hold switch when attempting.
Sony centre - no stock
Yodobashi - jpy4810, excl tax
Bic camera - jpy4880, excl tax
This is in Nagoya.
Apr 2, 2017 at 5:11 AM Post #10,929 of 45,723
Apr 2, 2017 at 12:52 PM Post #10,932 of 45,723
  What headphones can I us SONY MUC-M12SB1 cable for?
Bit of advice on this one the mmcx connectors suck big time, they are ok if you plug them into the Z5's and leave them but removing them a few times makes them loose. I guess this could be the case with any mmcx iem's your going to use them on, i have had to re terminate 2 pairs with eidolic premium connectors.
Apr 2, 2017 at 4:01 PM Post #10,934 of 45,723
400 hours reached with about 200 on each output (75% burn in with IsoTek burn in cd and rest listening). Can't claim that I remember what it sounded like from the start but it certainly sounds fantastic now. JH13 with trrs and Z1R with trrrs. I should have my trrs to trrrs adapter by then end of next week to be able to use my JH13 proper balanced. Then I'll also be able to try HE-6 balanced but don't really expect that to be anywhere near ideal.
Apr 2, 2017 at 4:32 PM Post #10,935 of 45,723
Hi,
Just received my wm1a today, and I'm looking to upgrade my iems. I've had ie800s and SE846 in the past, but I'd like something different that either has, or can use, a balanced cable and compliments the wm1a.
Being in the UK the choice is a bit limited, but what would people in the UK recommend that is relatively easily available. I wouldn't mind going back to se846s with a Moon Audio Dragon 4.4 mm cable, but I would prefer something a bit different and something that doesn't involve import tax!
Sorry for the vague question, but I'm open to all suggestions! Budget is around £1000 including cable.
Thanks for your patience!
Status
