hung031086
Any recommendations for a good 4.4mm copper cable ?
Its a 8 braided copper cable.
Can get at Sony store.
I suggest you try out other brand copper cables see if suits you.
I would say the Kimble Kable under Sony brand is good for average use but not the best. Take note the mmcx plug is on the loose side, too much of removing will make it more loose.
