It's most likely due to the size of the UPG file. The bogus ones are less than 1K so it loads and realizes it can't decrypt it and reboots. The DMP-Z1 file is much larger so that's way it takes longer to realize it can't decrypt it and reboots.
Shifting genres - All About Eve
A time and a place, so much emotion with this album, simply builds and builds, 22 years on absolutely nothing has changed - In the Meadow, demands to push the volume...
The Walkman doesn't seem to recognize the files as videos, even though they are within the mentioned specifications... They are seen as audio files and they will play as such, without displaying a video.
I thought Music Center may support importing videos to the player, and maybe it would do a conversion or something, required to play on the device, but no luck.
However, it seems that Music Center has the DSEE HX integrated into it:
Also, it support direct access to a DAC via WASAPI or ASIO, which is pretty cool!
My 1a on region J and i tested wm1a-z1 with ier-Z1r and fir audio M5. Both of them have a same result. I'll try it with the other region. Thanks for your support
