gerelmx1986
My wm1A got a little brother, the A55L
Congrats to the mum !My wm1A got a little brother, the A55L
Wouldn’t the WM1Z be the father, the WM1A the mother, and all else would be considered kids and cousins?
My GF saw the post and asked why is the WM1Z the father and not the WM1A?
I'm not touching that.
Allow me. The 1Z is gold and the TOTL DAP by Sony. Second best is the 1A.
So to summarize, the 1Z runs the show. This is coming from a guy that owns the 1A.
Nope, it's definitely the other way around, cause she sure likes her bling.
WM1Z & Z1R Combo. With Spinfit. Sound is so damm good still trying to solve comfort issue. As I have smaller ear, some metal portion touches the ear, which gives pain after 45/50 mins. But still I love it...The sound is like Food...
I have the exact same issue. No solution as of this writing as far as I know...Folks, need some help on the firmware update.
I currently have the firmware 3.01 and trying to update to 3.02 on a Mac. My Mac is currently on 10.15.1 version (Catalina) and when I try to update the firmware on NW-WM1Z, I get error message 60010.
Has anyone tried to update the firmware on Mac using the 10.15.1.
Sony website says that the download is compatible with Mac OS 10.12, 10.13.
Stuck in a situation and need guidance.
Thanks
You may want to try adding a cable clip to hold the cable in place around the Y split. This will stop the weight of the cable from pulling back your IEM and putting more pressure on your ear. You can also try re-shaping the ear hooks - bend towards your head to put less pressure of the ear piece against your outer ear. If the ear hooks are pre-formed silicon, a heat gun or maybe a hair dryer will provide enough heat to bend.
Thanks a lot for your suggestion. I will try. Regards..You may want to try adding a cable clip to hold the cable in place around the Y split. This will stop the weight of the cable from pulling back your IEM and putting more pressure on your ear. You can also try re-shaping the ear hooks - bend towards your head to put less pressure of the ear piece against your outer ear. If the ear hooks are pre-formed silicon, a heat gun or maybe a hair dryer will provide enough heat to bend.
The WM1Z has been released for over three years and yet I still have to see any number of WMport adaptors by third parties. Very unfortunate.Hi guys & gals,
Can anyone please recommend a short WMport to USB cable? I’d like to use the WM1Z as a DAC with my phone for streaming, but the stock charging cable is too long. I’ve seen a cheap one on eBay but just wondering if there’s a particular one that is recommended and fairly durable.
Thanks in advance!
Hi guys & gals,
Thanks in advance!
