phonomat
- Jan 28, 2013
I would say my budget is $499, and not sure if that would be sufficient for a good cable?
lol?
If you like single end, balanced will blow you away.
Get a good balanced cable, and unfortunately quality is synonymous with price. When you have good synergy between iem, cable and player, it's music heaven!
Is there a way to figure out where a "unknown" song is stored in the Library? I've got a few songs that have been mis-tagged or were free samples and ended up under the "unknown" heading. On the Fiio M11 I had, you could look at the information and it told you where the song was stored.
I would assume so but honestly can’t say as I have never connected to an amp
I've used Forza Audioworks Copper and Hybrid,Silver & Copper cables on my IEMs,with outstanding results,the Hybrids especially so.The difference with IEMs is meant to be more so than with full sizes cans.Headfonia ran a review some years back,that was their conclusion.Just compare a high purity copper and high purity silver cable. Probably will hear the difference.
IEM will be easier to hear the differences than headphones. Also depends on how much potential your iem/headphones have.
If a cable already maxed out the potential of your cans of cause changing cables will give you very little difference.
Cables are your final upgrades, only for fine tuning after you decided on your best IEM/Headphones and DAP combo.
I'm thinking of getting a WM1a,I've been sitting on the fence for a while! Great battery life,a major plus for me.Reportedly,excellent SQ.Looking at Sony's spec sheet and the supported files,they don't mention WAV.WMA but not WAV.Am I missing something? All my files are in WAV,to my ears,the best SQ and by some margin.
Final question,is there likely to be a WM1a mk.2 any time soon?
That's strange.. On the Help Guide page it lists WAV: https://helpguide.sony.net/dmp/nwwm1/v1/en/contents/TP0001449080.html
I can't recommend the WM1A enough. It was a revelation for my Legend Xs. I raved to an audio buddy and he bought one and sold his AK. He was as amazed as I was at how good it sounds.
As for cables..This is kind of a fun example. Scroll down in the comments where someone has put the time stamps 4:11, 7:10 and listen. With decent headphones/earphones I can hear a difference, particularly in something like the "ting" of the cymbals for instance.
This is by no means an "objective" test and could easily be discounted but I find it interesting nonetheless.
I'd not heard of WMA.I assumed that WAV would be an automatically supported file,but as I say,I've not had to consider it before.Apple do support WAV,albeit somewhat reluctantly I imagine. It would be great to hear from someone who's playing WAV files on their WM1a,or maybe I truly am a dinosaur! Thanks!Under the specifications on Sony.ca they list:
AUDIO PLAYBACK
AAC (Non-DRM), AIFF, ALAC, DSD, FLAC, HE-AAC, Linear PCM, MP3, WMA (Non-DRM) so they must've just taken the list from Sony's site but I've listening to APE on mine which is listed under the help guide.. Not sure why the lists are different
