SONY NW-WM1Z / WM1A
Status
Not open for further replies.
May 28, 2018 at 5:47 PM Post #20,657 of 45,723
Well I can only go on my observations and the cable I'm using is solid silver with rhodium and platinum/palladium connectors with silver internal wiring on the Z7's has shaved off 10 on vinyl rips 24/192 and on dark side of the moon DSD 18 and brothers in arms MFSL DSD 15 and 20 off wish you were here DSD and on my iems 64 audio with the same cable build I've turned off high gain and the volume is 45 now
May 28, 2018 at 5:52 PM Post #20,658 of 45,723
I am a recent (yesterday) purchaser of a Sony NW-WM1A, and I have newbie question:
How (if at all) do I use it as a digital transport to send bits to my DAC? I tried the WM Sony Proprietary - to - USB cable to a USB hub to the USB input of my Schiit Gungir Multibit DAC (to convert from the USB A of the Sony cable to the USB B cable of the DAC), but it doesn’t seem to be the right way...I get a red light next to the power switch on the WM1A, the battery life indicator oscillates from 0 to 100%, and I can’t find any signal.
Is there some setting on the WM1A I have to use to inform it that I am trying to get it to send bits out, rather than receive bits of a load or volts of a power line?
May 28, 2018 at 6:24 PM Post #20,659 of 45,723
Is there any talk of Sony going to an Android based system for their next release, or do we think they’re locked in on their current software?
I personally hope not, the Sony UI is rock solid
May 28, 2018 at 6:25 PM Post #20,660 of 45,723
You’re going to need this
May 28, 2018 at 6:26 PM Post #20,661 of 45,723
I certainly hope not. I love the Sony user interface.
May 28, 2018 at 7:12 PM Post #20,662 of 45,723
Thanks... oddly enough, I had ordered one for my ZX1 long before I bought the 1A, but Grand Meister, the amazon supplier, lost the order and I never got it, so I didn't bother to order another.
Now I have... thanks!
May 28, 2018 at 9:50 PM Post #20,664 of 45,723
[Just sharing]
33769005_2419036501443612_97849126053478400_n.jpg 33764258_2419050564775539_3354775736312397824_n.jpg 33862974_2419050551442207_8733148163361210368_n.jpg
Never thought that after months and I am still in love with my WM1A.. Love how clean, dark, detail and soft it is.
P/S: just bought Benks transparent case for my WM1A. Neat. Fitting is good. Protection 7/10. Aesthetic 9/10 (fingerprint).
May 28, 2018 at 10:39 PM Post #20,665 of 45,723
[Just sharing]
Then never try WM1Z. It's darker than WM1A from what i tried in shop.
May 28, 2018 at 11:40 PM Post #20,667 of 45,723
What are your overall impressions between the two Sony DAPs, and which do you prefer? What was burn in time on demo units? Love the 1A, but lusting for the 1Z
May 28, 2018 at 11:50 PM Post #20,668 of 45,723
[Just sharing]
Dark as per sound signature or dark as per background?
It sure is one of the darkest player in terms of background but never dark in terms of sound signature. 1Z is a fair bit darker in terms of sound signature.
May 29, 2018 at 12:01 AM Post #20,669 of 45,723
Not sure the burn in time, it probably there more than 1 year since it is released. I am using 4.4mm
If you have a WM1A burn in for more than 500hrs balanced and still wowed by it. That's something. I was listening to the song that was preloaded in.
It sounds like an old slower pace instrumental song, something like jazz. The background is so dark. The feeling was so real, like i am listening it LIVE at the venue with the singer singing to me.
Other more rock or faster pace songs, i have not tried in the player yet. I only have a brief 10mins listen to the player as i am curious. Nice experience i would say.
May 29, 2018 at 12:04 AM Post #20,670 of 45,723
I have 300 hours. Love it, but upgrade-itis is setting in.
Status
