Nah…I don’t listen to music on my way to work and mostly on call. So it goes in my bag.I always thought the big advantage of the Walkman was, that you could use it while Walking, hence the name^^
SONY NW-WM1Z M2 / WM1A M2
It is dangerous to use it while walking if we use IEM, it is still doable with earbuds or on ear headphonesI always thought the big advantage of the Walkman was, that you could use it while Walking, hence the name^^
I always use it while walking, since years, nothing dangerous happened so far.It is dangerous to use it while walking if we use IEM, it is still doable with earbuds or on ear headphones
But I mostly use it while train or plain rides. As I stopped owning a car, I am capable to listen to a lot of music while gazing out of windows.
In combination with the IER-M9 and good foam, Its possible to enjoy music in perfect quality unrelated to where you are.
The1Signature
what is the name and model of this case?I just put it in this hard case on my way to work and not worry about vibration or scratches
i used peli 1040 for wm1zm1 + ier-z1r.
for wm1zm2 + ier-z1r i would need the peli 1060.
WAmadeusM
- Sep 8, 2016
So...who has had the chance to compare an original WM1Z running @MrWalkman vrs WM 1zM2? And what were your impressions???
https://evergreencases.com/products...1&_sid=20a6a356f&_ss=r&variant=39616007634989what is the name and model of this case?
10DeeQ
- Jan 6, 2013
How do we do this? Im a noob in android worldSomeone could try this:
Enable gestures
Code:adb shell cmd overlay enable com.android.internal.systemui.navbar.gestural
Disable gestures
Code:adb shell cmd overlay disable com.android.internal.systemui.navbar.gestural
Is that cubed foam? I have the same in a Pelican 1060 but never got around to making the shape for the Walkman. Seems very easy to just get the shape, but how do you get the depth just right? Doesn't seem to come out in perfect cubes depth wise.
Ya those are cubed form like below. Easy to manage to create perfect shape to fit Walkman and IEMIs that cubed foam? I have the same in a Pelican 1060 but never got around to making the shape for the Walkman. Seems very easy to just get the shape, but how do you get the depth just right? Doesn't seem to come out in perfect cubes depth wise.
But how do you pluck them out at the right depth? I am getting perfect separation length and width wise, but for the depth it doesn't seem to detach in perfect cubes. Any tips?
Will send you the pic of bottom layer. Since the Walkman has some weight so 2 layers of foam is what I left I guess but will check it once I’m home.
rlw6534
https://android.gadgethacks.com/how...stures-work-with-any-custom-launcher-0238065/
It works on the A300 and ZX700, I don't have WM1A/Z M2 to test. It will either work or not. If you get an error, then Sony completely removed an Android feature, rather than hiding it.
Daytripper
- Jul 28, 2013
Hello all,
I just bought a Japanese nw-wm1am2 about a month ago within seconds of listening I knew this was an awesome music player.
I am new to android, iPhone and mac guy. No problems with dap whatsoever everything works flawlessly.
my problem is I transferred music from apple music on a mac ripped years ago and a huge amount of album art is missing.
Is there a way to install an app that will find the missing art and put it in place on the Sony?
long time lurker TIA
Check out the tags on the files to see whether the images are embedded. Something like dbPoweramp will let you download the art.Hello all,
I also copy the cover into the root folder of each album called "Folder.jpg". Not sure if that's needed nowadays though.
Daytripper
- Jul 28, 2013
There is a file in the Sony above the music files labeled Folder.jpg when I look with android file transfer, drop there or in each and every album that has no Artwork.Check out the tags on the files to see whether the images are embedded. Something like dbPoweramp will let you download the art.
Thank you turbojet.
Total: 47 (members: 26, guests: 21)
