Well I have been using the v6's for awhile now and I am very pleased with them. I get no static or hissing even at max volume. I havent really been playing any games that have great audio; been playing Dungeon Siege and Gunbound. Still both sound great and there is definatley a difference between my old phones (Koss UR20) and the v6's. AFAIK the audigy series only pumps out 32 Ohms for the headphone jack no matter what version. These headphone technically require 64 but, they sounds fine to me. It seems everone here says that you benefit from an amp, but being on a budget and mostly using the headphones for gaming and some music it really isnt a big deal to me. They sound great the way they are!
I have also knocked them on the floor at least a dozen times and they are fine. These things are built to last!
As for the "spring cord" it really isnt a big as a deal as I thought it would be. I thought it would keep getting stuck on my desk or the back of my computer case but it happens very rarely and when it does, just a little tug and its fine once again.
I also took some pics of my little escipade:
The old original pads. They were flaking off and it got black stuff everywhere. You can see that there is a little sheet of fabric on the inside. I chose to leave that in so it wouldnt be blasting directly into my ear and for the added comfort. I used plain old elmers glue to attach them around the earpiece.
The driver of the v6's. Here you can see another piece of fabric around the driver. This is a discomforting for a little bit of time until you and the phones adjust to one another. Now I can easily wear them close to two hours.
The new pads! So soft! So smooth! OOh Aaaah. Getting these on are kinda tough. I could have used an additional set of arms to hold it and poke it in with my fingernail at the same time.
The finished product. Ta Dah! Comfy and Plush!
This is all I can think of for right now. If anyone even reads this thread again or finds it on a search, Ill anwser any more questions you may have. Ill see you on the radio!
