Sony MDR-MV1
Apr 11, 2023 at 6:09 PM Post #31 of 461
Apr 12, 2023 at 4:23 AM Post #34 of 461
looks plastic.
actually from sony's japanese website, the 'developer interview' mentioned it being aluminum alloy:
https://www.sony.jp/feature/products/230411/?s_pid=jp_/headphone/_products/_MDR-MV1
There's a part under Point 3 about the lightness of the headphones.
Google translated:
The first thing that strikes you when you pick up this product is that it's "light!" You have succeeded in making it lighter than you could imagine from its high functionality and appearance. What kind of difficulties did you face?​
Ozaki: We used a lightweight, high-strength aluminum alloy for the housing, and then reduced the thickness of each part by a few percent. We proceeded while measuring each part. However, even though we are talking about weight reduction, it would be putting the cart before the horse if we only wanted lightness and made it difficult to use. The ear pads of the MDR-MV1 are thick enough to make them comfortable to wear. It was difficult to determine where we could shave while maintaining performance that we could not compromise on, even if the weight increased a little.
Apr 12, 2023 at 9:55 PM Post #35 of 461
Sony Fanboy checking in, will be keeping a close watch. After many years of ownership, I sold my MA900 earlier this year, and I knew immediately I had made a huge mistake. I hope it will be easier to buy replacement pads for this because MA900 pads were really hard to come by even, when I got it in 2016.
Apr 13, 2023 at 12:30 PM Post #39 of 461
Apr 13, 2023 at 2:21 PM Post #40 of 461
MM-500 MM-100
MSRP$1,699$399
StyleOver-ear, open-backOver-ear, open-back
Transducer typePlanar MagneticPlanar Magnetic
Magnetic structureFluxor™ magnet arrayFluxor™ magnet array
Phase managementFazor™Fazor™
Magnet typeNeodymium N50Neodymium N50
Diaphragm typeUltra-Thin Uniforce™Ultra-Thin Uniforce™
Transducer size90 mm90 mm
Maximum SPL>130dB>120dB
Frequency response5Hz – 50kHz20Hz-25kHz
THD<0.1% @ 100 dB SPL, 1kHz<0.1% @ 100 dB SPL, 1kHz
Sensitivity100 dB/1mW
(at Drum Reference Point)
98 dB/1mW
Impedance18 ohms18 ohms
Max power handling5W RMS5W RMS
Min recommended power>100mW>100mW
Recommended power level>250mW>250mW
EarpadsPremium LeatherGel-filled Leather
Weight495g385g*
*Audeze has not confirmed the weight yet
Updated spec. Thanks to @deafLovesMusic
Apr 13, 2023 at 2:29 PM Post #42 of 461
Gentlemen do we have a weight for the MDR-MV1 yet?
It's 223g (wow!) according to B&H's product specifications. MM-100 vs MDR-MV1 will def. be an interesting comparison.
Apr 13, 2023 at 2:38 PM Post #43 of 461
Really looking forward to what the MM-100 can offer at the low end frequency range.
Apr 13, 2023 at 3:26 PM Post #45 of 461
MDR-MV1 MM-100
MSRP$399$399
Transducer typeDynamicPlanar Magnetic
Magnetic structuren/aFluxor™ magnet array
Fazor™
Magnet typeNeodymiumNeodymium N50
Diaphragm typeCurved corrugation diaphragm shape
and Tri-duct structure
Transducer size40 mm90 mm
Maximum SPL100 dB>120dB
Frequency response5 Hz - 80,000 Hz20Hz-25kHz
98 dB/1mW
Impedance24 ohms18 ohms
Max power handling1.5W RMS5W RMS
Min recommended power?>100mW
Recommended power level?>250mW
EarpadsSuedeGel-filled Leather
Weight223g385g - TBC Audeze has not confirmed the weight yet
AvailableEU Pre order, US Pre order, APAC?US Pre order shipping June, EU ? APAC?
