chromatic
- Dec 1, 2010
Yes, over-ear design will have less microphonics, these models will come with several tips so you can achieve the best isolation/comfort.
EX800ST should be the best model for you, for studio use I can also recommend the ATH-CK10, very low microphonics, comfort, flat FR, high detail retrieval, dynamic range etc., the Sony's will sound more natural in timbre though so it's like a studio monitor versus a high-end natural speaker, it depends on if you're mastering recordings or creating music and selecting the best sounding instrument in a virtual database (for example).
Edit: Oh, and for your needs, these are also a very popular choice, I haven't heard them, but I have to be objective and fair =p http://www.etymotic.com/ephp/er4.html
Hey thanks kiteki
It was very interesting, and i didnt know about those Ety er4 and the ATH so i will check it out
In fact i will not use those earphone in my studio but as iam indeed using studio monitors and headphone for work i would like to have earphones with a similar sound response (mostly flat) when listening music outside etc etc so i can keep my ears used to the same type of sound.
it would be cool also if the earphone respond well to EQ (from my cowon j3) to add a bit of bass some time to see how a mix sound on a more comon type of earphone... because of that the 16mm driver of the sony might be a good option...
So ok with your advice i will focus on the Sony 800st and look at the Ety4. What do you think about the Shure Se535 ? i had the se530 for a short amout of time and i liked their sound, but fit was just a little bit inconfortable so i decided to send them back during the dirst week i had them to be able to get my money back... maybe it was a mistake, i donc know if i could have just got used to it overtime... since the SE535 seem a bit smaller i wonder if it will be more confortable...
By the way i wonder how much different the sound of the EX1000 will be from the EX800 saddly not so many peoples have the 800 yet so without trying them its difficult to know...
The most confotable earphone i used are the Sony i got with my Sony mp3 player sw846 they have mostly the same shape as the 800ex without the over the ear design and the driver is 13mm instead of 16, they are not studio earphone by any means (they have noise canceling system so it add a slight hiss all the time ) but they are very very confortable... saddly also they have probably the most Microphonic i have ever heard... :S
thanks for all
PS: after a bit of reading the Ety seems to transmit easly microphonic noise by the cable so i will pass on that...
still there is the Sony 800ex and the Shure...
The ety website was interesting as they explain that to compensate the fact that the earphone is inside the ears a gain around 2700hz is needed to get the same sound as a live or monitor response,,,
