HotIce
- Sep 9, 2014
At the same price, why would you buy a clone?
They had me quite intrigued... they were actually a bit cheaper (though only by $20 bucks) and when I demoed them clones at the store they actually sounded surprisingly close enough 7506's (of course, no extended comparisons or anything but just generally)... and their detachable cable option was very, very tempting as well... plus also just the novelty of trying something completely unknown (there are literally no reviews for them out there)... but yeah, eventually, I thought to myself I just wanted something that works well for my use and Sonys are tested and true, so I ended up with them anyway.
I wanted to make a new thread but I can't
So I'll just post it here
I left my newly bought mdr 7506 on max volume for 1-2 hour. Will it damage my headphone?
Absolutely the best headphone I have used for
sound and comfort. One thing all 7506 owners should do is to change the earpads. Get the sheepskin leather pads from B&H this headphone has gone from best to absolutely outstanding in comfort and sonic audio quality. What a huge difference these pads make, they are expensive but well worth every penny.
Are you talking about those Auray pads? I was actually thinking of getting the extra deep ones (which I don't think is the version you are talking about)...The sheepskin leather pads are different pads than one you mentioned. This pads is miles above the stock pads in terms comfort and sound quality. They are shallow but because they are all leather and of high quality me ears did not feel any discomfort even after several hours of use. No sibliance is present. All aspects of sound quality were greatly improved. My search for the go to headphone for all my listening needs have been met with this headphone. And the pads made a world of difference for me.
Any significant sound differences you notice with your pads vs stock pads? I'd definitely like some comfort but wary of possible sound changes as I love their sound with stock earpads (though a bit less sibilance would be nice).
That'll be interesting Alchemist. I also have the 7506 and 220. I won't say too much since it may 'colour' what you say.
I really like the 7506 to work with, but then it's eq'd. At home, it's a little more hit and miss, depending on what you're listening to. I find the easiest way to control the treble zing is just back down the volume a fraction and then most stuff sits well musically.
What would make me nervous of buying a new pair though is the number of 'fakes' flying about. Even some sellers aren't aware that they're selling fakes!! The copies are pretty hard to tell if you don't have a real one to compre with.
I like the 220 but not so sure about mid shoutiness and the comparative softness in the treble with it.
