So I absolutely hated the Z1R when I first got it, tried every single OEM tip and none of them gave me a good fit. I then ordered the Comply 200's... omg what a GAME CHANGER. I get goosebumps when the bass drops in the EDM I listen to. Absolutely amazing! I can't wait until I get the Symbio W peel to try... tip rolling is addicting! Only thing is, my right ear sounds a bit more quiet than my left. I wonder if this is a driver defect, or a fit problem. I know these are pretty well built, but I bought it second hand. They don't look like the have any external cosmetic damage to them, but I just worry how likely can these be internally damaged?
The Sony IER Z1R sound is so addicting. To me it sounds so perfect for my preferred sound sig. it hits all boxes. I just get lost in the music. A true classic!
Has any compiled a list of the tips compatible with the Z1R? Would be awesome if a fellow tip roller compiles such list and perhaps even a short review of all of them
If you're going to trust my ear tips review and haven't buy any ear tips yet, i suggest you to get the "AZLA SendaEarfitLight Short".
As @Tristy tell his impression, I'm curious and brought the "AZLA SendaEarfitLight Short" for more than a week, but too lazy to update my impression post.
It's simply a combination in between AET07 and Final E.
In short, it keep the bass level, texture, decay and soundstage depth of the Final E, also the mid-high boost and the clarity of AET07 but not as extreme.
If anyone is looking for sh IER-Z1R in EU that have only few hours of usage I'm selling my pair.
Love the sound but the discomfort kills all the love I have for them
Does anyone know if iBasso's CF01 true wireless adapter fits into the Z1R's recessed MMCX sockets? if so, anyone know if it has enough power to sound decent?
thanks!
thanks!
The photo of the connector would indicate that it will not fit since Z1R sockets are recessed and the CF01 connector has a rectangular shaped base. In fact, when I got a custom cable made with Eidolic connectors, I had to peel back the clear heat shrink on the barrel of the connector to make it fit so the tolerance is less than 1mm.
