Kiats
Wow. I’ve been listening all day to my new IER-Z1R’s. Love them; love that sub-bass and natural decay sooo much. Didn’t think I would buy the Z1R’s. I was skeptical they would fit well since a trial at a local meet (with too large of a tip) was not convincing that they would be as comfortable as my IER-M9’s. Well, with the right tip size these things fit my ears like a glove (I’m using hybid S (small) on Z1R and Triple-Comfort S on M9 for better isolation since the M9’s are my “outside” IEMs). I’m rocking a deeeep insertion on both.
I was also hesitant to buy the IER-Z1R due to the reports of recessed mids. Well, I can honestly say, for me, the whole frequency response is totally to my liking. I had to do some major PEQ to get the MDR-Z1Rs to my liking, but out of the box these IER-Z1Rs are perfect for me.
Cheers,
Gus
Glad you like the Z1Rs. Yes, they do look a bit clunky at first impression, and need a cable that allows you to fit it in properly and precisely. Once you select the right tip to get a good seal, they are easily one of the most cohesive and attractive hybrid universal IEMs around. I was sceptical like yourself too. It sounded wonderful off the Sony 1A and 1Z as it should since they are part of the same signature range from Sony. But I was very pleasantly surprised by its synergy with the AK SP1000Cu and AK SP2000Cu. It meant getting the Eletech Plato with 2.5mm balanced plug, where @Eric Chong got me excellent connectors which are long enough for the Z1R and slot in with a satisfying solid click. The transparency and crystal clearness of the Plato is excellent for the Z1Rs. Definitely pushes the Z1Rs up to a different level. Of course, the stock cables that Sony used this time is also excellent.
Kiats
gerelmx1986
VancityDreaming
How does the WM1A pair with the z1r?
gerelmx1986
Really good airy highs, non fatiguing midrange and nice deep digging bass with slam and feelingHow does the WM1A pair with the z1r?
musicinmymind
- Jan 31, 2012
Wish someone compare ZX507 vs WM1A pairing with the z1r, I wanted 507 more because of streaming features.
I am powering my IEM-Z1R's from the Chord Mojo. If I was to get something else with Balanced output what can I expect?
For those with and without the balanced outputs could you determin which output was being used in a blind test?
1slyB
You probably wont see a difference overall, the sound signature will probably be the biggest difference. The difference with most balanced portable output devices is there is a power increase from unbalanced to balanced. When I tried with my desktop amp, there wasn't a major difference with other headphones between the two. What balanced is there for is to reduce noise, if you have any decent amp and similar output it is unlikely to notice a difference overall. If you happy with the Mojo no point to change unless you have a noise issue or want a different sound. Any decent unbalanced amp with low noise floor will be comparable to an balanced amp.
nc8000
Balanced can also give better control over the headphone (not just more volume) if single ended is borderline in power to control a more demanding headphone
At this point, i just wish sony can make custom m9 and z1r. After discovering deep fit of m9, im blown away how m9 can sound so different than my regular tips size. Ive demoed z1r too, probably i love m9 more than z1r. A reason why i have m9 not z1r. Nevertheless, these things are holographic af.
Edit: what i discovered after this deep fit, the resolution of M9 is significantly better, the holographic is scarily good. Also, due to this deep fit, there is almost zero spike on upper mids now. I believe z1r will benefit from this too. Sadly i didnt deep fit z1r before. A reason why custom is always a better choice.
VancityDreaming
Damn. This is on the verge of being dirty talk. HahahReally good airy highs, non fatiguing midrange and nice deep digging bass with slam and feeling
ops, please delete for me moderator.
Infoseeker
I imagine the Zx507 probably can't drive the z1r loud enough.
I imagine the Zx507 probably can't driver the z1r loud enough.
It has no problem driving the Z1R's
musicinmymind
- Jan 31, 2012
From different post, I read Zx507 is better than sp1000m and WM1A has better sound stage than Zx507. Portability we do not have any DAP which is sonicly as good as WM1A and does streaming.
