Jun 27, 2019 at 6:01 PM Post #3,436 of 16,321
Whar I noticed is that campfire audio are really good until you put them sids by side woth a few others. Andro and Solaris near M9 and Z1r are quite "strange".
Well done mate, glad thst you're happy.
Try to use the biggest triple comfort tips and seal from outside your inner ear. That helps keeping those sharp edges out of your ear edges. That's how a got rid of that pain.
Jun 27, 2019 at 7:00 PM Post #3,438 of 16,321
@candlejack which tips do you use with your z1r ?
I haven't settled on any one set yet. I'm focusing mostly on the stock silicon tips (the foamies are not secure enough - similar to what you were telling me - but I haven't really experimented a lot with them yet).Today I had SS in my R (the one with the soreness issue) and MS in my L. Wore them in super deep mode. Tomorrow I'll try L in both with a shallower insertion. I get a good seal with quite a few options, the only problem is fatigue and irritation after a while. Stock silicon tips, .
To everyone: do you go for super deep, deep, medium or shallow insertion? And why, is it for sound or for comfort?
Jun 27, 2019 at 7:05 PM Post #3,439 of 16,321
I wouldn't go as far as "strange." From the stuff I've heard (granted, a fairly limited set), the Andromeda and the Solaris come in 2nd and 3rd for natural sound.
Thanks, I'll try to see how that works out, but I have a feeling they will slip out.
Jun 27, 2019 at 7:23 PM Post #3,440 of 16,321
I'm not reading 200 plus pages, got a lot so far but IER-Z1R vs LCDi4? go!
Hi, Pete. I've got both and have done some A/B in the past couple of weeks. I prefer the Z1R FR over the i4, even with Cipher/Reveal. Isolation is also no contest. However, the i4 is simply the best IEM in terms of soundstage, imaging, and transparency -- transparency in the same way that the SR009 is transparent, like looking through a pair of glasses that don't have any lenses.
I use the i4 in the same situations where I would use an open back headphone, except it's a lot more comfortable for long listening sessions and it's mobile. I have young kids and I need to be able to interact with them or hear them cry, while at the same time have my own music playing while they watch Frozen for the 5th time that day. It's also nice for walks in a quiet neighborhood since you can still hear the sounds of the world. It's like having a portable speaker set with you while you're out. But, it can be finicky to get a good fit and it's somewhat fragile.
The Z1R has really good isolation and can be used anywhere and in any situation. The fit takes some adjusting to at first since it is such a large IEM. My ears were sore for the first 2 weeks until my holes got stretched out. I'm just glad my holes didn't have to get used to the big, black Z1Rs. The FR of the Z1R is close to my idea of perfection. The bass timbre and tuning is awesome, but I actually found the treble to be the standout in this IEM. There's no weird spikes or dips that are audible, which makes for a very smooth and accurate presentation. Soundstage isn't as wide as some of the other IEMs in this class -- Solaris, Anole VX -- but it's not in your head either. I hear the Solaris at about 2 MCM, whereas the Z1R is at 1.75 MCM. MCM is a soundstage measurement using perceived head widths.
Overall, if you're going to be using it mainly for mobile use, which I think you are given your TOTL headphone habit, the Z1R is a better choice.
Jun 27, 2019 at 7:32 PM Post #3,441 of 16,321
I had a hard time "getting" how the Z1R should fit. What helped for me was to take off the tips and just insert the shells into my ears. Then it made sense to me to use a far smaller tip than I was used to. However, I ran into the same problem as you where the post edge dug into my concha. It would leave red marks in there and grew to be quite painful. Now, I use the L Hybrid tip with a medium insertion, just enough for the edge of the faceplate to tuck into the concha but without the post making contact. I love the sound but still not the most comfortable IEM for me.
Jun 27, 2019 at 8:11 PM Post #3,442 of 16,321
I have been tip rolling as well trying to get that perfect fit.
I keep getting back to the stock tips included because somehow they fit me the best compared to even my most preferred tips for everything else (Ortofon size M). The hybrids won't stay in so I have to stay with the silicone. S will give me deep insertion but the the fit is very loose. What I end up with is going with MS. Best seal and a secure fit for me.
For me, comfort is number one.
Jun 27, 2019 at 8:45 PM Post #3,443 of 16,321
Thanks, very interesting. I'm going to try to demo both and hear the pros and cons of both of them.
Jun 28, 2019 at 1:29 AM Post #3,444 of 16,321
I think i have a shallow fit.
@candlejack Do jou have the same comfort issues with the finale audio tips.
With the finale audio tips the cilinder part is still touching my ear but I am not feeling it and comfort is great for multiple hours.
Jun 28, 2019 at 1:42 AM Post #3,445 of 16,321
the lcdi4 are to me, the best iems in the known universe. the sony ier z1r are my second favorite that i've ever heard. im positive nothing out there is better than the i4 but there may be ones that are better than the ier z1r. i love the ier z1r however. simply put, the i4 brings life to music. you wont realize how dead all your iems sounded if you've never heard the i4s.
Jun 28, 2019 at 1:45 AM Post #3,446 of 16,321
^ lol?
I had that problem with my Oriolus v2, and it drove me nuts, but in which way does it cause you "major pain"? Is there a suction effect of some kind or something? For me, it was mostly the clicking noise whenever I touched them to correct the fit or whatever that got on my nerves (with the Oriolus).
well if the driver inside is pressured when you put the iem into your ear, then so is your eardrum. there is mutual pressure. over a period of time. the pressure combined with the sound waves cause major pain. its the only real dealbreaker for me. i wouldnt even use the orpheus in iem form if it had painful driver flex.
Jun 28, 2019 at 7:27 AM Post #3,447 of 16,321
The fight of the y-ear is about to start! Who will win? Make your bets and more to come. :)
64 Audio A12T vs Campfire Andromeda S vs Sony IER-M9 vs Sony IER-Z1R
FOR THOSE FREE FOR A LONG READ. :)
Before even starting I would like to remember that whatever I write here about these IEMs are completely subjective and in this case it's my unique opinion, feel free to have yours, but always remember to respect your forum colleges.
Ok, let’s go, I will divide this into scores and music genres, 1 for top and 4 last (spoiler, none of them are bad).
Let’s start where everyone starts when they buy a new pair of IEM.
Unboxing and Presentation:
Do I need to say that Z1R is the best unboxing experience in the IEM department EVER? I remember when I saw them for the first time on a local audio show and the guy handed me the box and said to open, it was like opening a pandora box, when you open the “lid” and it opens to show the IEM carrying case, drawers and everything else. Unforgettable, even knowing that would never be the same as one opening your own one, the one bought with hard owned money (my girlfriend jokes that she would ask me with that case and IEMs inside and that even the best ring I would give her would not beat the Z1R on the carrying case). The M9 was the closest to that sensation, all beautifully thought and placed in the box for the best impression. Then 64 audio and your name on the case and opening for one’s custom made and long waited personal look, but simple and robust
on other aspect, expected as this is made for musicians on tour. Campfire has that common experience as every IEM from them simple paper-box-case-IEMs, like hiding Gems, not an expensive beautiful piece of art, boring to be honest.
(1-Z1R, 2-M9, 3-A12T, 4-Andro)
After the first impression opening your long waited new babies. You jump straight to try them. Now you come with the second point of this impressions…
Comfort:
On this one I need to mention how well Sony thought about customer experience and didn’t measure costs when designing the M9, this was designed to be used by musicians on stage and moving around. They are extremely robust, light and comfortable, the triple comfort tips + M9 makes you forget you have something in your ears really easy. The magnesium shell makes total sense in this case and small diameter bore makes it easy for insertion on small years like mine. A12T comes just there too, hard to compare CIEM and UIEM, but I’m impressed with M9 comfort and placing and removing an UIEM is easier. But the CIEM is as good as your ear impressions, with a few exemptions of fit issues. Then Andro S (not the former greens), they are comfortable but has some weight to it that when moving around makes it also move and sometimes lose the seal. Then comes the Z1R, this one was made to have the “best sound signature” and look good first and then the fit without compromising the first two. It is heavy and on small ears the sharp edges will touch some points of the ear, some may not care, but I do when I have the other three at the same time.
(1-M9, 2-A12T, 3-Andro S, 4-Z1R)
But you guys may say “I don’t care about those things go to the main point; how do they sound compared to each other?”. Ok, now that you have your babies in your ears is time to pump your best tunes and get your mind blown away…
That’s what I did and by this time I was on a Hip-hop mood, so I started straight away pumping songs from Wiz Khalifa and then Billboard Hip-hop playlist from Tidal. Right to the point, Z1r has the deepest, more extended and more charming low end of all (period). Feeling like a room with a multi-thousand-dollar stereo hi-fi setup. M9 has the deepest Low end for a BA. A12T is really really close to M9. Andro has the shallower Low end but still detailed and kind of in place. The DD of the Z1r gives a deep and extended low end that fits amazingly well for this genre. The BAs from the M9 and A12T are deep but on a fast and quick way that also makes this style enjoyable with them, but miss the deep rumble of a well implemented DD like the Z1r. The Andro S is more focused on the mid-highs and the miss on the low end makes the highs more pronounced and, on some songs, actually sparkly.
Talking about mids, all four IEMS can all be considered V shaped, with A12t showing better clarity/details anywhere between deep lows to highs, M9 not far behind being really slightly muddied compared to A12t. Z1r being the more relaxed and putting the singer a bit more behind, but detailed as necessary to make the song pleasing like having a 2.1 sound system. Andro mid low and mid high feels more blended compared to all others, strangely not in a good way for me. Jumping to the highs, Andro has a clear and detailed highs but totally sparkly compared to the others. A12t with amazing controlled Highs. Z1r with nice high extension never ever sparkly, highs right enough. Imaging and sound stage all are well represented here, only M9 having the narrower sound stage of them, as expected as it is made for stage use. I won’t get int too much details as hip-hop is not the best to try soundstage. :)
Quick song examples with deep bass, male voice, strings and sparkly highs that one can see who can handle the whole frequency is “Old Town Road (Remix) – Lil Nas X, Billy Ray Cyrus”, or “Wow. – Post Malone”, “Sunflower – Post Malone, Swae Lee”
(1-A12T, 2-Z1R, 3-M9,4-Andro S)
Conclusion for now:
Z1r even being placed last in Mids, that made it lose the first place, is still the best for this kind of music, not because of the audiophile sharp knife way to compare things, but for the pleasure and enjoyment it brings to the kind of music in this genre. Reminds the big American cars with big subs,
that is exactly the kind of sound Rappers look for. The A12t is by far the most balanced one, best allrounder. the best value for the buck will go for the M9, not the refinement of the Z1R, but same sound signature for a whole lot less. I used to love my Andro, but putting these 4 together, the findings were definitely a big surprise. Taking the comfort out of the equation, the gap between Z1R and M9 increases, making it more realistic, but for me comfort is as important as all the rest. Not that Z1r is unusable, it is just heavier than all others and has some sharp edges that you will definitely feel after a couple hours.
Done with Hip-hop lets make a sweet transition to Classic and progressive Rock.
Here is where things get more interesting as the deep and extended low end is not under the spotlight as before and the whole dynamic range, speed of the transition and highs extension are more important on the long guitar riffs, vocals, drum cymbals and plates. But don’t be fooled the Z1R can shine here as much as any other. Roger Waters déjà vu is quite a complex song that cover all frequencies really well, A12t again was the best balance and detailed one, but Z1r performed really well with incredible details for the low end focus this one has. M9 right behind with incredible details and not sparkly at all. Andro, the best Mids just behind A12t and as expected really close to M9 but brighter than the others and sparkly on the highs. “Dream Theatre – Forsaken” Mids I wanted to see on the Z1r, really balanced all the way even with a male voice, but slightly on the background. "Mastodon - Ember City", makes the M9 shine on the Imaging and Separation, impressively much clear than the others. Steve Wilson's Periah, is another example that again makes M9 Shine. A12t showing amazing separation/imaging and Soundstage on both of then. For the friends that loves the old masters' Led Zeppelin, try “Ramble on” and see for your self the soundstage and imaging of the Z1r as well as on “Black Sabbath – Planet Caravan” where we have a percussion on the back that you can lay down close your eyes and hear every beat flowing from L to R, totally separated from the guitars. Not a classic rock, but still worth mention, "Foo Fighters - Sunday Rain" you will get a good imaging and soundstage example where A12T and Z1r outperform the other two.
The results kept A12t an allrounder, but Sony showed that M9 sound signature is a good choice for this genre as it is more balanced on all frequencies, sub bass is not getting more attention than Mids as it is expected on Rock songs. Impressively Andro S and Z1R were really close in score, but for different reasons, one has the best low end and highs and the other has the best Mids. Money for the buck is again with the M9. impressive results for the cost compared to the others.
*I had to stop the comparison of the all four here as the Andro got sold.
Wrapping up my findings here, I can say that these results got me by surprise, as listening to each of the IEMs by itself on a “relaxed” mood with no intention of comparison I loved all of them for their own signatures and feelings each one brings. But when putting them on the same desk and at the same time, the differences between them are clear. As I mentioned before Z1R is the most enjoyable fof all, with the feeling of “grabbing a beer, a nice book and relaxing on the couch after a tiring day”, that is priceless, but going back to the beginning, they were designed with two things in the priority list, sound and look, comfort was not priority here and after a couple hours these IEMs will remind you that. The A12T is the most detailed and controlled on all frequencies bringing forward Low/Mid/high when needed by the song, definitely and easy to love signature, if you’re looking from a CIEM, keep them on the list to check, on the other hand is the most expensive of the list and takes some time to be built and to get to you. I can’t guarantee the same sound as the UIEM version as we all know tips and fit changes sound. But I expected these results for those two, but what impressed me the most was the M9/Andro S results as they have similar price, but totally different sound, for this price M9 is a no brainer. More balance and control than the Andros, deeper low end when needed and no harsh highs on any song I threw at it, when Andro struggled to keep the control and went sparkly. For my preferences theses guys won a place on my all time “top” list.
Jun 28, 2019 at 8:42 AM Post #3,448 of 16,321
@Giullian Thanks for FINALLY providing your impressions. :-)
Jun 28, 2019 at 9:45 AM Post #3,450 of 16,321
@McMadface Yes, you know me well. I'm all TOTL. I own the true-wireless in-ear model by Senn, that I received for free. I've never been into in-ear models or just never gave them a chance and would be commuting with them. So I would be jumping to the top tier off the bat and not even getting anything in between the low and the high end.
