Sanctuary
- Jun 19, 2011
In my understanding of this, the manLOUD eq helps alleviate issues with capturing BRIRs and HPEQ on a closed ear canal and should thus be useful for all speakers, not just the L/R/C.
That's what it should do, but after watching the tutorial again, it specifies that when you are using manLOUD, it has to be tied to a specific PRIR. So I don't think it would actually be useful for what I was wanting to do at all. It might make a BRIR sound better to my ears, but I already have a decent enough 7.1 PRIR, and was trying to add additional speakers from a BRIR.
Using manLOUD in this case might help make the BRIR speakers sound better, but then it would make my own PRIR speakers sound worse I think. I'm not sure using the Composite feature would actually be a way to circumvent this either. I would be able to combine the various sources into a single PRIR, but since the PRIR and BRIR being used would have tonality/room differences, I doubt manLOUD would work well in that case, and would be similar, if not the same as simply making a room with manLOUD BRIR speakers, with my own PRIR.
