Dixter
- Dec 21, 2011
what I am going to suggest may or may not fix the issue of where there is no sound but you load a different room and the sound comes back...
The suggestion is ... create your rooms at the top of the list... location 32 and below that number... I am wondering if the rooms aren't being fully loaded and so when you switch to a different location and the sound comes back.... maybe... and this is a stretch.. if there are rooms at the lower numbers ( the factory ones) and a few at the highest numbers like 32 if it would force the A16 to load the rooms correctly and thus not have the issue of no sounds.... its just a thought to try out....
