Fox1977
Maybe indeed it plays MKV but not Atmos and that may be why I kept in mind that Apple TV is no good for me...I would need to double check, but I'm pretty sure it only outputs multichannel PCM, not ATMOS from VLC on ATV.
So you either have XLR inputs on your A16 or plan to use XLR to RCA cables?Great thanks for the tip. My checkbook has been preoccupied purchasing an Octo 8 Dac Pro this month. So maybe next month I'll fit a NVidia Shield into the budget.
Not sure why I would need either XLR or RCA inputs going from either an ATV or a NVIDIA shield. Don't both video and audio go over HDMI from either unit?So you either have XLR inputs on your A16 or plan to use XLR to RCA cables?
Sorry, this pretty much a simple question but really do not know how to get past it.
So, after admittedly quite a long time I wanted to use my Smyth Realiser A16 for watching some video via Netflix on my iPad. Latest camera adapter, plus lightning power.
No sound.
FiiO M11 coax in, no sound.
Both tested on my Soul DAC & headphone amplifier. Works.
Also used the “Test” button on the A16, No problem at all.
A16 always says no SPDIF Signal or nor USB signal.
Also scrolled through many profiles. Re-loaded everything. Nothing. Nada.
Any ideas?
Do you have the A16 working with other sources/inputs? For example analog stereo input? Have you installed a different firmware version since the last time it worked?
Only things I can think of now, probably you know, but just in case that you don't:
I was referring to the Okto DAC 8 Pro. It has 8 XLR outs, plus USB in/out. It does not have an HDMI out. As things stand right now, the A16’s USB input has yet to be configured via firmware. The A16 Pro model, of course, is configured to accept XLR ins. Years ago when I owned a Blue Hawaii headphone amp I used cables with XLR on one end and RCA on the other to connect my DAC to the BH.Not sure why I would need either XLR or RCA inputs going from either an ATV or a NVIDIA shield. Don't both video and audio go over HDMI from either unit?
I'm not planning on inputting anything to the A16 from the Octo. The Octo is my use case for 5.1 channel sound input from my PC for when I want to use my speaker system. The remaining two channels of the OCTO will be input the SPIDF output of the A16 (converted to AES/EBU via a Canare transformer).I was referring to the Okto DAC 8 Pro. It has 8 XLR outs, plus USB in/out. It does not have an HDMI out. As things stand right now, the A16’s USB input has yet to be configured via firmware. The A16 Pro model, of course, is configured to accept XLR ins. Years ago when I owned a Blue Hawaii headphone amp I used cables with XLR on one end and RCA on the other to connect my DAC to the BH.
Thanks for the clarification. Makes perfect sense.I'm not planning on inputting anything to the A16 from the Octo. The Octo is my use case for 5.1 channel sound input from my PC for when I want to use my speaker system. The remaining two channels of the OCTO will be input the SPIDF output of the A16 (converted to AES/EBU via a Canare transformer).
The A16 is my use case for when I am using headphones for multi channel audio or stereo. As mentioned above, its output will be passed via spidf to the Octo, and from there via XLR cable to my THX 789 for my two headphones. (HD800, and LCD X).
I am not sure but what I understood from different pieces of information is that Smyth again is forced to a hardware change and adapting to that, or at least there is a hold up in hardware delivery (due to a big fire at some chip/board manufacturer that touches the entire pro audio business). Or something like that.Any new shipments in the last couple months? Getting a little nervous.
My current PRIR is only 6.0 from an imperfect nearfield home setup, so I didn’t think there would be any interest.There are today 4 people that I can see on the dropbox. People who graciously donated their PRIRs issued from their Realiser A16. It is not a whole lot considering the number of followers on this forum and the +- 300 A16s in circulation.
But who am I to talk about the dropbox since I am personally not contributing to it in any way (I possess no personal PRIR).
No offense guys. Just wondering aloud…the why![]()
