I started making PRIRs a week ago, and I finally cobbled together my first 9.1.6ch room using a pair of
Dutch & Dutch 8C monitors.
This being my first attempt at creating an A16 PRIR, I had to create three separate PRIRs to complete a 9.0.6ch room. I'm sure if I remeasured everything in one session, I could produce a single 9.0.6 PRIR and improve volume level matching of the center channel as well. At some point, I may go back and redo the measurements. However, remeasuring everything is not an ordeal I wish to revisit at this time. I've uploaded all three files to the
Google Drive that I believe was created by
@Rene Lou.
To create a full 9.0.6 Atmos and/or PCM room, you'll need to use the Listening Rooms menu to combine all three PRIRs. The Google Drive folder also contains a _Readme file. This file contains additional notes on each file, along with specifics on how to combine all three PRIRs (see instructions below). It should be noted that none of the PRIRs include a subwoofer measurement. This omission was intentional because that the 8C is the first stand-mounted monitor I've heard that can reach 20Hz in my room. That said, I'm pleased to report that I'm satisfied with the sound of the resulting 9.0.6ch room, although the majority of my listing is limited to two-channel music.
If you achieve respectable results from the Dutch & Dutch 8C PRIRs, let me know either via this thread or directly via PM.
06/09/20 Update: I will be uploading a new PRIR in the future that can be used to create a full 9.1.6 Atmos/PCM room. Stay tuned. Thanks
@audiohobbit for raising the issue. See
this post for more information.
Title: Building virtual rooms from multiple PRIRs
Description
With the Realiser A16, virtual rooms can be created using multiple speaker measurements taken at different times. These instructions are an example of the steps needed to create a new virtual 9.0.6 room by combining three specific custom A16 PRIRs. If different PRIRs are used, the steps detailed here may need to change to reflect differences in other individual PRIR files. These steps are specific to my personalized Dutch & Dutch 8C measurement files.
Process Summary
1. Transfer the PRIRs to the A16
2. Build new Atmos/PCM rooms
3. Load the new virtual room number into presets
Process Details
Step 1 - Transfer the PRIRs from an SD card to permanent storage in the A16
1.1 Download the PRIRs from the Google Drive (or any other source) and copy the files to a properly formatted MicroSD card
1.2 Insert the MicroSD card into the A16; Power on the A16
1.3 After the A16 completely boots to the Speaker Map, press the Menu key on the remote; From the Main menu, Scroll to Files; Press Enter
1.4 Scroll to MicroSD PRIR; Press Enter
1.5 Scroll to Copy to A16; Press Enter
1.6 Scroll to MicroSD to Permanent storage; Press Enter
1.7 Press Back to return to the Files menu
1.8 Repeat steps 1.4 thru 1.7 for each PRIR you wish to transfer
Step 2 - Build new Atmos/PCM rooms
2.1 From the Main Menu, scroll to Listening Rooms; Press Enter
2.2 Scroll to Atmos (or PCM) Rooms; Press Enter
2.3 Change the Atmos (or PCM) room number to a room number of your choice
2.4 Press the Right Arrow key to move to the Key symbol; Press the Adj+/Adj- key to unlock the room entry (the key color will change from Red to Gray)
2.5 Scroll to Listening mode; Use the Adj+/Adj- key to change the value to 9.0.6
Select the first PRIR (D&D 8C 7.0ch Time 15:08)
2.6 Scroll to Channel 1 (Left) in the virtual speaker list; Press Enter
2.7 Select the Permanent PRIR Files entry from the list; Press Enter
2.8 Use the Adj+/Adj- keys to select the desired PRIR number; Make sure the desired file Name and Date/Time appear on the display
2.9 Scroll to Select All Matching Speakers; Press Enter
Select the second PRIR (D&D 8C 7.0ch Time 19.37)
2.10 Scroll to Channel 3 (Center); Press Enter
2.11 Select the Permanent PRIR Files entry from the list; Press Enter
2.12 Use the Adj+/Adj- keys to select the desired PRIR from the SD card; Make sure the desired file Name and Date/Time appear on the display
2.13 Scroll to Select One Matching Speaker; Press Enter
2.14 Select the Channel 1 (Center) entry from the virtual speaker list; Press Enter
Select the third PRIR (D&D 8C 9.1.6ch OH)
2.15 Scroll to Channel 1 (Left); Press Enter
2.16 Select the Permanent PRIR Files entry from the list; Press Enter
2.17 Use the Adj+/Adj- keys to select the desired PRIR from the SD card; Make sure the desired file Name and Date/Time appear on the display
2.18 Scroll to Select All Matching Speakers; Press Enter
Save the new room
2.19 Scroll to the top of the Atmos Room page
2.20 Press the Right Arrow key to move the the Key symbol; Press the Adj+/Adj- key to lock the room entry (the key color will change from Gray to Red)
2.21 Press the Back key to save the Room
2.22 Repeat steps 2.1 thru 2.21 to create a PCM room
Step 3 - Load the new room number into presets
3.1 From the Main Menu, scroll to Presets A or B; Press Enter
3.2 Use the Adj+/Adj- keys to select the desired Preset number
3.3 Scroll to the Atmos or PCM entry; Use the Adj+/Adj- keys to select the desired room number
3.4 Scroll to the top line of the Preset menu; Press Enter to reload the preset
3.5 Press Back to return to the Main menu
3.6 Repeat steps 3.1 thru 3.4 for each User and room type as needed
