audiohobbit
It doesn't. It has tactile preouts though. These you can connect to the amp of the shaker, but not the shaker directly to the Realiser!Since the A16 has a separate amp for shakers
I strap mine to Ikea Poang 24/7, and I add 1 thin pillow to make the headrest thicker. I find it comfortable as my everyday lounger, and I have a bad back. It's always ready which is how I like it.The S2 is strapped on an armchair ? I’m watching from a couch. I thought about the Subpac M2 but I’m afraid it might not be comfortable if I’m resting my back on the couch with the M2 strapped on myself
That sounds like it would work perfectly for me. But, as I recall, they did promise a separate low-wattage amp for shakers.It doesn't. It has tactile preouts though. These you can connect to the amp of the shaker, but not the shaker directly to the Realiser!
I own a Subpac S2 tactile subwoofer. Have had one for four years, used it w OOYH, and yes, it makes a big difference. Everything seems to go at least half an octave deeper with it in use.
Since it has its own amplifiers, all I've had to do was split off the output of my headphone amp, and send one leg to the subpac. Since the A16 has a separate amp for shakers, I'll undoubtedly experiment with it as well. As soon as I get it back from Smyth.
When Smyth changed from one prototype to the final prototype that 25 Watt amp was dropped, as was the instrument input.But, as I recall, they did promise a separate low-wattage amp for shakers.
Do we know if the Illusonic mixer is also a permanent scratch, or just a promise delayed.When Smyth changed from one prototype to the final prototype that 25 Watt amp was dropped, as was the instrument input.
All right but after the year is up:This is some old news from the French importer from last October 2018, if it helps :
...quote " what takes the longer is the software development, since the hardware has been finished for a long time. Once delivered, there is already a programme of at least a year of software updates to add functions :
(note: the order of priority is not yet defined)
- 96 kHz for a user. The current processing of the A16 is in 24 bits / 48 kHz.
- vertical head tracking. Currently, it is on the horizontal plane only (head rotation)
- the opening of the USB connection for other uses (combo headset for gaming, DAC, binaural recording, management of a keyboard)
- Internet browser control
- the Illusonic upmix
- Auro 3D decoding
- low latency mode to allow musicians to use the A16 to hear themselves playing on a virtual stage without delay
- an optimized mode for the game, with integrated chat (virtual voice positioned in space)
- the menu in several languages "...unquote
Please don't kill the messenger...you may still need me !
Nope, the Exchange website has not been activated yet. Maybe they'll mention it in the next weekly updateThanks!
Isn't the Exchange website active yet or is there a temporary problem?
I tried to make an account but got a message that registration is closed at this time and should try again later.
I remeber when having to choose between the 2U or headstand version we had to choose a color as well.
Does the 2U version come in silver also?
