- Nov 26, 2002
Quick feedback on my first foray with the A16 today:
- unit arrived this week (kickstarter #63) with 2 headtrackers per order
- i could hook it up to my 2019 imac (osx mohave) through USB (installed the driver which made it recognized as 16 channel sound card)
- i could load my aix prirs (A8 files) and store fine
- i could make an hpeq of my verite headphones although I had to adjust hp and mic gain settings a bunch of times (and never could get the signal to be green for the whole sweep)
- I had the latest firmware installed when I received the but an older firmware in the micro-usb card when I loaded the prirs files from aix
- I am not sure if the realiser automatically looked for this firmware but fact is that, as I had setup automatic firmware update upon bootup option, a firmware update occured when I started the unit
- i did not pay much attention to the firmware versions and copied the latest firmware to usb , went through the manual firmware update process just to be sure before proceeding with trials
- i also disabled the firmware update check on startup since it probably makes little sense
Trial 1 (mac USB out):
- i was able to test 5.1 and 7.1 speaker layout using the midi control panel on the mac (each speaker was properly virtualized after I set the output channels)
- however there was no way to store the speaker layout settings (it always defaults back to 2.1)
- as a result of this, I was never able to playing a multichannel stream properly through USB input in the realiser (any channel beyond 2.1 was messed up, played each on L/R or mix or none of them)
- i tried many different dolby test tracks (5.1, 7.1, 9.1.x etc) but all failed the same
- I tried multiple settings using itunes, vlc, and quicktime players, none worked
Trial 2 (mac hdmi out through an owc thunderbolt 2 dock):
- The mac realised a 1080p device was connected through hdmi (it would switch the display resolution)
- However, I could never get the audio stream to be picked up by the realiser
- I tried bistream and pcm, various encodings to no avail, this thing doesn’t work as advertised...
Trial 3 (blu ray, and atv connected to realiser through hdmi, hdmi passthrough to the tv):
- I could finally play movie from atv but with major lip sync issue (dolby room)
- I need to play more with this but it’s going to be near useless without some lipsync feature
- Interestingly though, I then tried a blue ray with a 5.1 DTS HD soundtrack and, while I expected it would not play, it actually rendered fine through ... dts room?
- even more interesting, there is no noticeable delay there.
- Could it be that the BR play is decoding the dts stream and sending that as pcm through hdmi because the realiser does not accept dts bitstream?
- Furthermore, does it mean the bulk of the delay I notice is coming from the decoder in a16 rather than the convolution engine?
- only issue I have now with this is lack of audio passthrough which is a major pita as I certainly would prefer not to have to buy an AV receiver just for that...
I hope the experts perusing this thread may have suggestions or ideas
arnaud
arnaud
