sahmen
- Apr 6, 2014
So is the impulcifier fully Mac compatible? I tend to use Macs for most of my work and listening.
Unfortunately I think it's PC only at the moment, but definitely reach out to the creator - he's very responsive and seems happy to help. His username is jaakkopasanen on here or you can try through the apps GitHub page. Good luck!So is the impulcifier fully Mac compatible? I tend to use Macs for most of my work and listening.
Yes, it’s Python, hence, it also works on Mac (tested). Just the initial command for the virtual environment is different.
For playback you don’t need HeSuVi. Any convolver will do; such as Reverberate (free), SIR, Waves IR1.
If there is interest I can provide you with my bespoke standalone processor (based on processing libraries from the University of Huddersfield) made in Max MSP (no need for Max, though). You just need to route the audio into the app; using, for example, Soundflower (free) or Loopback (paid). I run a 48 channel virtual speaker system with this setup (made with my own deconvolver and processing setup), but it works with any other speaker arrangement.
HeSuVI and Equaliser APO are the easiest for doing multi channel playback (ala DTS/Dolby) though.
How much they sticking you for?Just got a phone call from UPS to collect the GST and import duty.
I was surprised at how well compensation profiles work on Creative’s Super X-FI amp. I still imagine that the Realiser A16 will offer the best headphone VSS solution and user experience for those with the cash and the ability to obtain decent HRTF measurements but I too have gone from considering purchase to now thinking it’s not worth it for the time being.Glad someone else has the wonderful Impulcifer working. It's free and we seem to get more communication and better support than a £4k device.
Some thoughts on the Realiser from using Impulcifer and with various home theater setups:
- Having a 9.1.6 HRIR in a tiny room isn't worth while. The reason you put in more channels than, 5.1.4 is due to the size of the room - if you have a small room stereo panning/imagining can take care of it. Even between a real 4 ceiling speaker vs 6, the only additional information you gain is the panning between the front and back. They're designed for bigger theaters. The 9.1.6 setup I've seen on YouTube that the Smyth's used at shows to capture is very small. So doing a 7.1.4 or 5.1.4 will be sufficient.
- The room sound matters much more than the speaker. The sine sweep process doesn't actually model the speaker transient response. You might find that the 9.1.6 measurement captured in a busy/non treated room won't be ideal. I've got multiple measurements from different seating positions and they all serve a purpose. The near field ones are good for many Dolby Atmos movies (you still get 7.1 vs 5.1 with Atmos). For two channel music I really like the measurement I took from 2.5m away from my speakers - it has a lot more room.
- Impulcifer is mobile - I used it in an airbnb for nearly a month via bluetooth headphones and a laptop hooked up to a TV.
- Impulcifer's dev is implementing exciting features in the future like virtual room correction (both frequency and time domain/RT).
For those into all this also check out DTS Headphone X v2. It's by far the best synthesised system I've used and it has headphone compensation - and it adds real height channels for DTS:X movies. You'll have to be on a Windows Insider build though. See my post on it if you're interested.
I was really excited that the Smyth started shipping, now reading through this thread I have 0 interest in ever buying anything from a company that communicates so poorly. The measurement process just isn't feasible to obtain Atmos. It's fiddly enough to work with Impulcifer and that's quite a simple measurement process - but you can't keep binural mics in and re-wire your AVR. Trust me when you start doing it, you'll get how fiddly the whole process is.
The syntheised efforts are also getting incredibly good. I was talking to DTS and they actually found that headphone compensation made a much bigger difference in their internal experiments than even personalisation. All the big companies have fingers in the ear scanning pie so pretty soon it'll be available everywhere. But for now anyone waiting jump on Impulcifer. Amazing stuff.
$237.82How much they sticking you for?
Just received an email from James Smyth at Smyth Research asking for my mailing address. Too early for April Fools, so this could mean the 3 years may finally be over!
Time to clear up the desk and change my earpads.
I was #13 on the Kickstarter backer waitlist back on Sept 2016
headstandGreat news! Did you pledge for a 2U rack or Headstand version?
