phoenixdogfan
- Feb 26, 2015
Checked the Realize Exchange website today and it had no studios/stores/venues local or otherwise listed. For me, a further reason to wait.
Does this 'widely dispersed stereo field' works against the possible cooperation with the Realiser?Yarra 3DX FAQ said:...
For more than 3 listeners, we suggest switching to stereo mode, in which one hears a widely dispersed stereo field.
In that mode it doesn't beam to individual ears anymore, so in that mode it is useless to feed it a binauralised signal. (But don't confuse this 'stereo mode' with feeding it a binauralised signal via a stereo input in the 'beaming mode' or whatever it is called. The name 'stereo mode' is a bit confusing in this context, it just means that it works more like a traditional soundbar - dispersion wise - in that mode. At least that is my interpretation.)Does this 'widely dispersed stereo field' works against the possible cooperation with the Realiser?
Thank you, i agree. But, are you sure that any analog 2 ch input can be treated other way than like a traditional soundbar? Ok, I know Yarra prototype was used with the Realiser A8, but other than that ...?In that mode it doesn't beam to individual ears anymore, so in that mode it is useless to feed it a binauralised signal. (But don't confuse this 'stereo mode' with feeding it a binauralised signal via a stereo input in the 'beaming mode' or whatever it is called. The name 'stereo mode' is a bit confusing in this context, it just means that it works more like a traditional soundbar - dispersion wise - in that mode. At least that is my interpretation.)
I'm curious how most plan to setup their A16. Mine will go below my TV, where my Xbox One X, PS4 Pro, Nintendo Switch> HDMI> A16> HDMI> TV> optical> 2 channel stereo. A16>optical>Creative X7 DAC>MICROZOTL2.
My X7/MZ2 sits next to my couch, with an optical cable traveling under a thick throw rug (currently use an optical switcher from the 3 consoles into the X7). I sit fairly close to my TV and stand, so I could connect directly to the A16. Just not crazy about headphone cables running across the floor.
I also imagine some have some very nice DACs and amps, and would prefer to use those over the built in. I upgraded the op amps in my X7 with Sparkos SS3601s and SS3602s. They made a tremendous difference over the stock, and a good difference compared to Burson V5i (which could just be a synergy thing with the X7). Compared to the Schiit Modi Multibit, if there's differences, I can't tell (and that's instantly switching between the 2, no idea which was which). X7 has some cool features, like answering phone calls, Bluetooth audio, USB audio, optical audio (which is 5.1 game audio converted to virtual surround), all controllable by volume/mute, which can be great while gaming. Only thing I'm not sure of is mic with the Xbox. Not really a huge deal, as I don't need one often, but that is what I am not sure of at the moment with a setup like this.
Actually, after having a quick look at some of the information I cannot confirm that 100% for sure now. Maybe someone else know's where we can find that information?Thank you, i agree. But, are you sure that any analog 2 ch input can be treated other way than like a traditional soundbar?
So you think it was 8 ch pcm hdmi output and not 2 ch processed output from the a8? That is probably right. And disappointing... The version where Yarra acts as the Realiser's loudspeaker for the 2 ch processed output sounds much better to me ...I think Mark Waldrep was only using the A8 as the demo source because the sound bar that he sells isn't Atmos compliant and he needed a 8 channel source for demos...
No, the A8 has no surround decoders of any kind, the only thing it could have been used for is binauralisation (of signals supplied by an external source).So you think it was 8 ch pcm hdmi output and not 2 ch processed output from the a8? That is probably right.
Maybe Waldrep only needed 8 hd pcm channels and that is something A8 can deliver ... l am not sure designers of Yarra had external binauralisation in mind.No, the A8 has no surround decoders of any kind, the only thing it could have been used for is binauralisation (of signals supplied by an external source).
