mathi8vadhanan
Never marry the same girl twice.
Westone W60 is the same shape (albeit smaller) and nozzle. It may fit snuggly with some foam padding.
Does anyone have a recommendation for an inexpensive portable USB DAC/amp to pair these with? I do most of my listening with a laptop and it's got a very obvious hiss when used directly. I have tried a couple of inexpensive options like the Schiit Fulla and it simply isn't a good match. I have to reduce my media player volume to like 10% just to get a comfortably low listening volume and the hiss is still extremely obvious.
I looked at the JDS Labs C5 but I'm not thrilled at the idea of paying for a fancy battery when I have no intention of using this thing without it being plugged into my laptop.
Finally, I definitely don't want to spend Chord Hugo levels of money, since I generally find the audible differences are pretty minimal to my ears.
I can sympathize. As amazing as the SE846 are, their sensitivity exposes you to hiss on a lot of devices. I had the same problem with my MacBook Pro. If you also have a MacBook, you'll be able to lower the noise floor a bit by going to applications->utilities and then running the Audio Midi Setup, selecting "Built-in Output" and switching from the (default) 2-ch 16-bit integer to 2-ch 24-bit integer (or even 32-bit float). This will lower the noise floor, but it won't get rid of it completely. You're going to be equally disappointed with the noise floor on the C5D or the Chord Hugo. I know I'm going to be crucified en mass for saying this, but one of the best DAC/amp combos I've ever heard with the SE846 is the boring old unaudiophile-grade iPhone 6. Its noise floor is incredibly quiet.
Not from me you won't!The iPhone 6 and Tidal HiFi and/or G'MIX/Neutron Player/Onkyo HF Player is sheer bliss. The QP1R adds just a bit more to the entire sonic presentation, but for all around duties that the iPhone 6 is pulling, it is one seriously legit DAC/amp/DAP/device!
I appreciate the responses to my question. Maybe I should just give up the dream and use my phone as a DAP. It doesn't seem to have the hiss problem that my laptop does, which probably makes up for issues with battery, capacity, etc.
Depends on your level of OCD, Hugo hisses with 846, which drove me to get the ZX2, but after listening to the AK240 and AK380, going back to the ZX2, I could then hear hiss I hadn't heard before (the AKs are inky black)...I don't think hiss is that big of a problem unless you listen to your music with no volume...
Bought yet another new player (AR M2) as a consequence...
I damned well hate this OCD
