Silver really brings out the detail. I can't way enough good things about Ted's service, quality, and price. I'm considering copper because I've noticed some recordings the highs can be a little fatiguing (ex. Smashing Punkins and some female vocals). Older recordings are fine however newer recordings and some of the reissues shorten listening sessions. I want something neutral and detailed but still fun to listen to for prolonged periods of time.
Shure SE846 Impressions Thread
- Thread starter jelt2359
Whazzzup
I think its time for a ted / dhc comparison review. I can only comment on alo and dhc.
olddude
Don't forget Moon Audio cables. Cost a bit more than Ted's, but great quality and extremely fast turnaround service.
Old Dude, Are you using the Black or Silver Dragons? Are you still using the Blue Filter MOD? I've been using the "Full Throttle" (without filters) as I believe you advocated at some point and only recently started using the Blue again but with stock cable.
MadGTI
- Jan 21, 2015
Hi Ivabign,
I hope you can help or anyone else that wants to chime in. I'm using Ted's Silver Litz, but thinking about going copper. Did you have the ALO SXC 8 with metal MMCX? Any issues with this?
How about any copper discoloration with Ted's Copper Litz?
You mentioned preferring the ALO for portability? Can you elaborate?
I have used ALO SXC 22 Copper balanced cable with AK120II, it adds warmth to the sound even though I used molded blue filter (which is supposed to be brighter), treble is not sparkling bright or fatigue and bass and vocals are sweet and natural and clear.
Thanks for the feedback MadGTI.
ubs28
- Aug 2, 2013
The Hugo is some what a bright amp so with the blue filters you still get the treble. Your phone might be warm sounding.
The hugo isn't bright, it's neutral. The bass of the Shure SE846 is even alot better on the hugo.
Agreed, Hugo is incredibly transparent, if you are hearing brightness I would suggest its showing something else in your chain, or a preference or being used to warmth.
johnwamp55
Aka: bmiamihk and numerous other aliases.
- Apr 13, 2015
Ok the hugo is not bright but so called transparent which is in no way close to being bright nor bassy.
zhxwn
- Jul 15, 2015
Hey! I was hoping someone could help me.i currently have the standard iPhone set up, iPhone 6 with EarPods, I listen to spotify 312kb/s.
I'm looking to upgrade and enter the world of hi res audio, I want something that will blow my mind, something that makes music feel refreshing and incredibly accurate.
I'm looking to get the shure 846 IEMs, as I've heard they are top notch, now, would plugging them into my iPhone defeat the purpose? Would I be better off purchasing a hi res audio player and cheaper earphones like shure 215s? What would give me the best sound quality? I can't afford the hi res player and the 846, the 846 will hurt my wallet for a long time, but if it's a new world of music enjoyment, I'll invest.
All info is appreciated! Thank you
xaddictionx
- Jan 18, 2013
The IEMs will make a larger difference than a DAP.
Imho the importance goes like this:
most effect on sonic quality>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>least effect on sonic quality
IEMS > music recording and mastering quality >> source (DAP and/or amp) > rest (cables, audio file format)
H20Fidelity
- Feb 11, 2012
The earphones should come first like mentioned. Most increase always comes from the IEM or headphone upgrade.
Your iPhone isn't bad at all, actually praised by many here.
Get the SE846, use them with your iPhone while you recover the outlay, then you can focus on a source (if you feel needed)
rawrster
- Oct 22, 2008
I run with my LG G3 phone, SE846 and audio tracks I have through poweramp. I would take that any day over the same setup except with a SE215 or similar earphone. The earphone makes the biggest difference here and it is significant. However a source such as a phone does limit it in a way. A better source will sound better however it is nowhere as close as the difference between a better earphone. On the contrast I'll take a superior earphone and crap source over a totl source and a SE215 or similar earphone without hesitation.
Tommy-27
- Nov 17, 2014
What are peoples thoughts on the filters? I thought that they wouldn't make that much of a difference. The difference is subtle but significant!. I have been experimenting with different tips and filters and I have just got to the black filter and think that I may like it best. I thought it would make it way too bassy but (to my ears) it doesn't overpower the other frequencies, it just makes the whole sound more lush and full. I think I need to go back and forth between blue and black to make up my mind. I read about the blue filter mod being the best but am reluctant to do that in case I mess up the filter. Someone kindly gave me some basic instructions on here but it wasn't completely clear and left room for error. If anyone has done this is it worth the risk? I tried the white filter and I think that it recesses the low frequencies a little too much and makes the music sound too lifeless (IMO) I am using them with a Sony ZX2. Which is your favourite filter and why? I would love to hear other peoples input on this
Total: 13 (members: 0, guests: 13)
