windplr
- Nov 14, 2014
The blue filter is the stock Shure sound. Good bass, good mids, good treble. Take out the filter material and it brightens up the trebles a bit with a slight lessening of the timbre (fullness). The white filter takes out 2.5db of the bass, the result being more treble but less bass. It has no material in it. The black filter is bass bass bass. Take out the material and they are still bass bass bass.
Tips and seal matter as well. If you can't hear a difference, make sure you have good seal. Try the Olive tips, they tend to fit well.
Waiting for my 846s to ship.
Can the blue filter mod be un-modded?
Also, I heard that Sprial Dots do not fit on the 846. Is this correct?
Cheers, Chris
