Treble harshness? My only quibble with the 846 is there's not enough treble.
+1. If these had the DITA treble, these would have been the perfect IEM (for me). But still my fav IEM..
What is your source gear / files?
There is no need to be constantly changing filters. The filters are I think designed to be more than "a bit of foam" since the whites have no foam at all. My advice would be to stick with the black filters only for a period of time and use the black olives in the appropriate size. I think it might just be a case of adjusting to the sound. I know I found the 8's a bit overwhelming at first. I've now progressed from Black to blue to whites over a period of a few months.
Haha..... 'You talkin' to me?'
You quoted me but I don't even own them.
Was curious what may cause the harshness as I'm in the market.
Also, make sure when changing these filters, you line-up the red dots. Very important. And that they are seated properly. This made a World of difference. If not, you may be getting the results I once did. I hated them until I read and got the advice from these forums. So helpful here.
Thank you, didn't have them lined up right when I went back to non mod blues. A lot more intimate sound now. Course I'm not sure about red dots, but they were just not quite flush so thanks for that.
I wish Shure had done a locking mechanism with the filter installation. I'm pretty OCD with stuff like this, so I repeatedly remove it/put it in until I'm convinced it's seated correctly. Rather than the red markings, I look at where the notch on the filter housing goes into the groove in the earphone and line up the insertion that way. But still, the way the filter housing can still tilt and easily move out of place bugs me. But how I check is to try rotating the housing while it's seated. If it doesn't rotate, then it should be in place. Then when I screw in the cap, I try very carefully to not knock the housing out of place.
I usually turn the filters slowly while applying very gentle pressure . You can easily feel them "drop down" and lock in so you can't turn them any more.
Like what Khan did to activate the genesis device?
And Ripley did when blowing up the Nostromo.
