bflat
CORRECTION - my original post noted "small" size when in fact the samples I got were "large". I ordered 10 smalls and the vendor was able to swap them out with large. All I had to do was pay a couple bucks to mail the smalls back.
I just got a couple of these as free samples:
Mushroom dome ear tips
I have to say, I am wearing the large size now (from small olives) and they are pretty darn comfortable and give the same audio characteristics as the olives. These are really tight seals and stay put. So far I have tried the following:
Small olives - tight fit, tight seal, great sound, but causes pain in my left ear after about an hour.
Klipsch large oval silicon - lighter fit, tight seal, just a tad less sub bass, causes slight pain in both ears after about 2 hours.
Mushroom dome - tightest fit, tight seal, great sound, TBD on how long I can wear before pain (if any).
In regards to comfort, the olives and Klipsch make the shell fit flush with my ears so that there is a lot of contact almost like a custom IEM. This is also causing some pressure on parts of my ear which creates a dull pain with extended wear. The mushrooms on the other hand, don't fit as flush and there is less contact of the shells to my ears. It's a minute difference of 1-2 mm but I think this will solve the pain issue for me.
