Loquah
Did you try my SE846s at the meet? I don't think I remember you coming over.
Wow, that would be awesome. I tried the Roxanne recently and it is the best IEM I have heard.
So I bought the Logitech UE900s remote cable for my SE846. I removed the memory wire within two minutes of receiving the package, as always. That ish is not allowed in my house. U AWARE? Cool little cable.
This is better than both the Shure AND Westone remote cables in every way. EXTREMELY soft cable and as always, comfort level skyrockets once removing memory wire. I totally forget I'm wearing these.
OH and the left and right channels are same length unlike other remote cables. This is awesome because when the remote side is longer, feels very weird with over-the-ear IEM's like Shure's. The right side being longer on those means the ear loop can come out from around your ear, it's a STUPID feeling. "Strain relief" blah blah blah. Even if I worked at McDonalds I could afford one of these every two weeks, let's try not to pop a blood vessel over this brahs
Sonically, nothing sounds off. Comparable to stock.
Pretty good cable as a daily driver IMHO
eyecandypr0n:
UE900s cable next to 93Spec pure silver:
Out of my 5 MMCX cables, the UE900s one is the most comfortable for me. Not bad for $30!!!
What tips do you guys use with these? The olives?
Do you think that the small holes on the shure tips affect the soundstage? I've found this to be the case with other IEMs, but then these are Shure IEMs with Shure tips...
Unfortunately I didn't, but doesn't really matter, I've bought one and it should be coming this week.
You meat at the end of the tip? That would definitely explain why my westone tips have a smaller soundstage. They have sort of a trumpet shape at the tip. Of the tip. Wut
I've tested out all the tips that came with it and found the default medium olives to be the best fit. The silicone was just uncomfortable, and I thought the yellow foam would provide a good seal to boost clarity, but its porous shell leaked sound and I lost a ton of detail. Your best bet from the stock sleeves is probably the olives. I also ordered a pack of the Westone True-Fit and Star-Fit, but found them to be rather horrid. I'm not sure if I just received a defective kit, but the molding was very sloppy. Some of the sleeves had bores that were partially covered. Those that were molded well had their own issues. Some of them slid onto the nozzle smoothly, but some also became stuck. I literally had to wrestle one of them off. I also found the fit to be rather off since most of the larger sleeves were elongated, which didn't bode well for my somewhat shallow ear canals. So at the end, I just stuck with the olives . . . for now anyway.
I can verify that the Shure silicone tips does shrink the sound stage. I own a few pair of Shures and have played around with the sleeves a bit. They're definitely not something I would recommend.
