Thought people might be interested in this. I asked Shure about SR25 and if it’s a good match. Here’s their reply:
Hi David
The Astell & Kern SR25 should be an ideal match for the SE846. The website Headphonesty.com has put together a good article covering the importance of pairing a suitable output device with your chosen earphones or headphones. Their article focuses on headphones but the underlying principles are the same.
As stated in the article, a ‘perfect’ output impedance would be zero ohms as it would always deliver the same output into any load. A ‘low-impedance’ earphone like the SE846 at 9-ohms falls within the guidelines of 2.5-8 times the source impedance of the Astell & Kern SR25 and they will make a good pairing. I hope you enjoy them!
Kind Regards
Sally-Ann
Shure UK
Hi David
- There are two types of impedance (measured in Ohms): headphone impedance and source impedance. Impedance matching between headphone and source is done to ensure a good combination of sound quality and sufficient volume. A match means ‘complimentary’ not ‘equal’.
- Pairing a headphone with an impedance of 2.5-8 times higher than the source impedance should yield good results. This recommended ratio is commonly known as the ‘rule of eighths’ and contributes to proper driver control (damping factor). Pairing a headphone with an equal or lower impedance than the source will likely result in unpredictable (poor) sound quality.
Kind Regards
Sally-Ann
Shure UK
