IEMusic
The iFi IEMatch goes between the source that has too high an OI, and the IEM itself. Recently, another member purchased one to use a sensitive all-BA IEM with his high-end headphone tube amp, that had a very high OI. It worked well, though not perfectly. The easiest test to see if you like the sound of the se846 would be to simply listen to it from your phone, or use a cheap dongle (Apple dongle works well). My source of choice for me se846 is the Dragonfly Cobalt.Thanks @IEMusic!
Do the iFi IEMatch need to be plugged into my SR25, or another source (like my phone) - can you recommend any other portable daps that I can look into?
I do really like bass, that's the thing but like I said in my previous comment, the BLON bass sounds more textured (and to me a tiny bit deeper) - if that makes sense?
That makes sense. The se846 has some of the most DD-like bass, with really good sub bass response and decay, but it still won‘t rattle your head the way some DDs can. The BL03 is at a borderline bass head level, so if that’s the kind of bass you’re looking for, I’m afraid you won’t get it out of the se846. Regarding texture, se846 bass typically has a lot of it. It is articulate and detailed bass.
