Shure SE846 Impressions Thread
Nov 19, 2019 at 2:32 PM Post #20,491 of 22,945
Well, the A&K player can't magically correct for the Andromeda's low-frequency drop-off. Maybe it has a (full, warm...) characteristic that makes you forget about it, but it would still benefit from an extended low-frequency range.
Nov 20, 2019 at 9:20 AM Post #20,494 of 22,945
Nov 21, 2019 at 5:00 AM Post #20,497 of 22,945
If I'm getting the WM1, I might be use my iPhone as the streaming medium.
By the way, what balanced cable do you recommend for Shure SE846?
The Hassle of having an extra bulk in your pants, go for it .
i had the FIIO LC-2.5 D balanced, High Monocrystalline Sterling Silver Litz cable. ( hope you can see the pics this time ) before i upgraded
FiiO Releases the LC-2.5/3.5/4.4-D Monocrystalline Pure Silver ...
https://www.head-fi.org › ... › FiiO
Diese Seite übersetzen
26.04.2019 - 15 Posts - ‎12 Autoren
FiiO Releases the LC-2.5/3.5/4.4-D Monocrystalline Pure Silver Earphone ... The upgrade earphone cable is available with 4.4mm balanced, .
Nov 22, 2019 at 5:08 PM Post #20,499 of 22,945
Is it normal for the big black SE846 box not to be able to close? I would have guess there would be some sort of magnetic catch so that it would fully close. The box lid basically comes down fully but the flap doesn't close.
Just wondering if this is normal?
I have the SE846s and they sound fantastic out of the FiiO BTR3 bluetooth amp. The bass is incredible.
Nov 22, 2019 at 9:30 PM Post #20,500 of 22,945
mine does the same, but its stored in its other box it came.
Nov 23, 2019 at 1:43 AM Post #20,501 of 22,945
Are you sure nothing's pressing up against the lid from inside? I didn't mess with my set's box much but it looks like the top might not be shut all the way. Usually a little magnet catch will hold the flap against the box if you push it there if it's fully closed.
I'd recommend using the little square zipper case it comes with. If you're uncomfortable with them flopping around inside that case, there's a little net pocket you can tuck them in that will hold them in place. Or I suppose you could cut a piece of the foam from the big box to fit in there and have the little holes for them.
Nov 25, 2019 at 7:56 AM Post #20,504 of 22,945
Finally back with 846s after black friday discount. First impressions, they went cheap on the box. I still have the box from 2015 and it came with the nice plastic case inside. It also closed properly. New one has no plastic case and doesn't close - like the photo above.
Having said that, don't really care about the box but if its important to you, something to note.
I have one question though, I tested removing the cable straight away and it was fine, but those little loose gold plates are very fragile. Are they important? Because I can see them breaking eventually.
