elfary
- Sep 29, 2005
Probably depends on the DAC difference between your Laptop and Zune. My laptop´s default output has bad quality but good quantity bass but it is overall much muddier sounding than my Walkman F which on all settings flat sounds with less but more tight and controlled bass. Also could be the case if you have some sound enhancements enabled on pc (EQ or something?). Using default filters with your Shures?
But what is the problem? you want more bass or less bass?
What it's going on is Zune's bass roll off. Or a 10 year old hpo design.
