e30ernest
- Jun 14, 2012
Any reason to stopping me from upgrading lol?
In my opinion, if you think it's worth the money, then I'd go ahead and upgrade.
This came off the Supplied cable while I was trying to change to a shorter cable. My 846 is barely 10 days old. Has it happens to anyone else before. I have previously owned and used mmcx connector before so I'm fairly confident about my technique.
I find the best sound quality in the yellow foams but they start hurting after 1 hour or so, so i switched to the silicone ones which are much more comfortable for long sessions. Supplied triple flangs are way too uncomfortable for me. There is a lot of talk about the westone star tips being more comfortable and of good sound quality, so i have ordered these.
Oh man just did an impulse buy because I couldn't refuse at this price. I had no issues with my original SE846 after owning it for 6 months except my cables are green from oxidation. Am I just crazy for owning 2 pairs of an IEM or headphone...
It was
It was hurting me also, but now they've lost that ability to spread, so its almost like having customs, they have shape of my ear canal.
A bit harder to get proper seal now, but still works very nice once seal is achieved ...
I'm just worried for hygienic reasons ...
You will need to order a pack of yellow foams to last a year or so.They get dirty after a couple of months so it's not ideal for long term solution.
medical grade rubber all the way
Can you post the source? Thanks.
Hi all,
I've had my 846's for a few months now.
Upgraded to a silver Litz cable which I loved, opened up the soundstage and clarity went up.
I however don't really get this subbass aspect. I've tried many tips, get a good seal, etc. Just not what I was expecting.
I'm using the white filters as I like that cleaner treble.
Also.
I keep hearing about the Chord Mojo. Thinking of picking one up. Will that improve the sound a lot? As much as the cable change did?
Regards,
Simon
Hi all,
Also.
Regards,
Simon
Hi all,
Also.
Regards,
Simon
The whites lose quite a bit of bass and in addition to silver cable the lows won't be as prominent as with copper cable.Change to blue filters,remove the foam preferably,put the stock olives and play The Night Of Rain by Tim Marley.If that doesn't do it time to join the basshead thread for advice.
