buffalowings
Went way too far, too many times.
- May 14, 2010
nevermind
Looking at the Internal Component View:
http://www.shure.co.uk/dms/shure/products/earphones/user_guides/se535-exploded-diagram_EN/SE535%20exploded%20diagram_EN.pdf
it would seem that the 535s have a Shock Isolator around the drivers. I wonder how good it is?
Regards
I've finally managed to pinpoint the exact reason why the 535s don't fit me very well. It all comes down to the angle between the cord and the body of the earpiece. Its just too small.
When I wear the 530s, its larger angle allows me to position the earpiece vertically with the "SHURE" text perpendicular to the ground. In that orientation I can get a tight seal with small tips and movements of my jaw or face do not cause my outer ear to push on the earpiece causing discomfort or loss of seal.
The small angle of the 535s combined with the length of the plug and the memory wire make it impossible for the earpiece to be worn in a vertical orientation. This pushes it against the outer ear, and when combined with its sharp corners (compared to the 530s anyway) makes it quite uncomfortable and prone to the loss of its seal.
If I detach the earpieces from the wires they will seal properly with comfortably small tips and are much less prone to losing their seal. Unfortunately, they produce no sound that way...Even then, the comparatively sharp corners make them less comfortable than my 530s.
It is now almost certain that I will sell them, but I'm still going to see if the large Complys produce a miracle. I am about to disembark at the last stop along the Universal IEM Line and start saving for a ticket on the Custom Molded Express. Maybe some ES5s...
In conclusion, I think I've discovered that anyone who wears their 530s 'vertically' like I do should probably stay away from the 535s.
Neither the SE530 or SE535 were designed to be worn vertically...maybe the SE530 worked a bit better in that regard, but both work better behind the ear for me.
Quote:In conclusion, I think I've discovered that anyone who wears their 530s 'vertically' like I do should probably stay away from the 535s.
I made a set of small spacers from the stem of the triple flanges to put on the nozzle and keep the foam tips from sliding down to the base. The medium Complys will seal, but only if I sit perfectly still and the medium olives will seal a little better but still not good enough. Unless the large Complys work miracles or I come up with some brilliant trick I think I'll be selling the 535s
