ken6217
From your list, each one has it's strengths and weaknesses, but I guess you could make a case that the 4R might be best for all around sound taking everything into account?
Ken
Ken
Ken
The 4R is the jack-of-all-trades, master of none, it can also handle the most amount of genres , but not in the best way. So I would say it's the most neutral out of the 3, however, it may sound boring.
Quote:The 4R is the jack-of-all-trades, master of none, it can also handle the most amount of genres , but not in the best way. So I would say it's the most neutral out of the 3, however, it may sound boring.
I wouldn't call the 4R boring
The W4's are pretty neutral and inoffensive... I can sort see that being synonymous with boring to someone who is a basshead.
If you want more bass, I'd lean more towards the W3 than the W4. I'd even suggest the TF10's for bass over the W4, although IMO, they're a bit lacking in the mids.
Gee, so much for going by the "rating chart".
I'm not sure which to try next? Was goIng to try the Westone. Now im not sure if i should.
It seems you have then Senn ranked low except for bass. I think Sony was supposed to be grainy (harsh)?
I had been listening to the 535's quite a bit over the weekend and when not listening, I had them playing to get broken in. The detail and soundstage compared to the crap I am used to is amazing. I just wish it had some more bass so it doesn't sound so thin.
So what gets the vote to try next?
Thanks,
Ken
Are there stores in NYC that you can audition IEM's?
Thanks,
Ken
If this helps, the music I listen to predominantly is Rock. I don't listen to jazz or classical. With that said, I would like it all in term of bass, highs, soundstage, detail. Maybe there isn't an all in one IEM?
Since you mention the W3, what am I giving up over the W4?
Also note that all of my listening is with an Ipod.
Thanks,
Ken
