TYATYA
Depending on how good the source is, you got better or not by EQing.Interesting I was not aware of the app.
I actually use this EQ while running analog input - so not using the Shure's DAC, just the amp. However, it sounds markedly better than a stock KSE1200 with these configurations.
Dan
The fact that kse's dac will runs when you turn eq ON, even FLAT.
Analog filter is big mechanisims. On nowaday devices are digital filter, your dac have to work.
If other components also good, you may hear difference of Bypass Eq v.s Flat Eq.
Below is Shure+ Play app eq UI
