Shure KSE1500 Review - Shure KSE1500 Sound Isolating Electrostatic Earphones
Feb 27, 2020 at 10:51 AM Post #4,876 of 6,080
You see I don't think you can. Not yet. Current BA drivers can't deliver the extended high frequencies that the KSE can. If I'm wrong, I'd love recommendations on any BA headphone that mimicks (or gets close to) the KSE's FR.
As you say, it requires a new type of driver. Maybe one day, there will be much smaller BAs that are equivalently light and fast. Once you have those high-frequencies in the FR, the impulse response will follow.
It is all about the FR :)
Lime Ears Aether R have kinda similar tuning. Not the same though.
Feb 27, 2020 at 10:52 AM Post #4,877 of 6,080
BA's are good, but the problem is range. That's why high-end makers are stuffing like 16 drivers in one earpiece, which is kind of Lol. Electrostat can do it with one driver.
Feb 27, 2020 at 2:12 PM Post #4,878 of 6,080
That is true - good observation! I wouldn't underestimate the importance of a 1-2 dB shift here and there though. In my experience, differences that small can make or break a headphone. BAs tend to be good at dumping lots of energy into the lower treble, but tend to struggle in the 10 kHz+ region:
Very true - and 16+ drivers per earpiece are just making these things too darn big. I suspect the future of non-electrostatic drivers lies in single, very thin and very light dynamic drivers, probably with conductive traces 3D printed directly to the driver surface.
Feb 27, 2020 at 2:19 PM Post #4,879 of 6,080
That's what the upcoming beryllium trend is attempting to do, like with the new Final A8000 and Dunu Luna. I can buy into it. IMO, it's a better effort to make a more responsive DD than stuff as many BA's in an earpiece as you can.
Feb 27, 2020 at 2:46 PM Post #4,880 of 6,080
I've had Aether R universal for review and noticed that they have some similarities with my KSE. They both tend to relay heavily on recordings themselfes to create a soundstage so they can be one time close and intimate and another time very open and stadium like. Both have snappy transient response and both have very good treble especially Aether for a BA based was impressive. Overall they are very good but way below what Shure can do with bass, transparency, resolution, etc, etc
Mar 1, 2020 at 1:52 PM Post #4,881 of 6,080
Does anyone on here know what the pin configuration is for the 6-pin connector? I’m trying to build an adapter to a Stax 5-pin but can’t find anything online. Thanks!
Mar 2, 2020 at 10:55 AM Post #4,883 of 6,080
Don't. The bias voltage for modern Stax headphones is almost 3 times the bias for the KSE1500/1200.
The bias voltage will be properly adjusted downward before KSE’s are ever attached.
I would prefer to use a KSE1500 amp/dac but can’t find one.
Mar 2, 2020 at 12:19 PM Post #4,885 of 6,080
There have been two examples I have found. The first re-wired the KSE1500 IEMs, permanently utilizing a Stax 5-pin plug and a Kingsound amp that had been adjusted. It was criticized because an unknowing future owner could plug them into any Stax 5-pin amp and fry the IEMs.
The second and more appealing approach built an adapter but left the IEMs with their original 6-pin connector. Same thing...using a dialed down Kingsound. Seems safer as the usage would only be possible with the pigtal adapter, which would make future accidents much less likely.
At any rate, I'm trying to get creative as I haven't found a KSE1500 amp.
Mar 2, 2020 at 1:04 PM Post #4,886 of 6,080
But why?
Mar 2, 2020 at 5:26 PM Post #4,887 of 6,080
If you're referring to my project...because I have a very nice pair of KSE1500 IEMs and no amp to power them nor have I been able to find a KSE amp available for sale.
Mar 8, 2020 at 6:57 PM Post #4,888 of 6,080
If anyone wants to play around with eq, I’d be curious what you guys think of this eq profile on KSE1500. I tinkered around for 2 hours and made 3 user defined custom EQ’s and kept the user defined 4 neutral for quick A/B. This here, imo, is the best sounding configuration I can get to have more musicality and the most natural sound delivery possible. Make sure to set your gain to never hit clipping (stay in green)
Very easy to copy the values, just scroll from 1. Mimic on screen, then move to 2., 3., then finally 4.
I don’t like hyperbole, but a stock kse1200/1500 is lacking a bit of versatility. But this eq (and another less aggressive one I’ve done) make any single iem on market completely irrelevant (Own IER-M9 for their great plug and play performance. Owned kaiser encore, solaris. Demo’d u12t, Z1R, Anole VX)
649A05E5-30FB-471B-85DB-CE7E47AD0E19.jpeg44F002E6-47AE-462A-90D5-DE6C34B9C868.jpeg59B47580-2FC5-4DE0-926C-22D7C3028CF7.jpegCA6C7628-9243-4315-B48C-F50813262A51.jpeg
Audio-Technica Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
https://www.audio-technica.com/
Mar 9, 2020 at 10:03 AM Post #4,889 of 6,080
Doing so, you hearing from Kse internal dac.
1. Sharp sound w/o refining
2. Narrow headstage
Unless you need a cleaner and shaper sound (may good for some kind of music), it is not as good as running from external dac - EQ bypass.
P.s I have not found a dac that could bring a sharp sound than internal one in kse.
Completely no echo, no reverb, no warmth, no coloring...
Dry and sharp.
Internal dac in kse makes me somtimes feel AK sp1000 is refine but coloring.
Ps2. If Iam not wrong, Shure's launched an app (android world) called Shure play which exact the one in kse.
I run it on my dap
Mar 9, 2020 at 10:38 AM Post #4,890 of 6,080
2. Narrow headstage
Interesting I was not aware of the app.
I actually use this EQ while running analog input - so not using the Shure's DAC, just the amp. However, it sounds markedly better than a stock KSE1200 with these configurations.
Dan
